A kernel update has appeared. The sound began to work. Volume function keys also. WiFi also seemed to be more stable. Thanks to the guys from Manjaro Smile
(11-08-2019, 08:36 PM)belfastraven Wrote: Question:  Obviously people are getting output on their powerbook screens, but I am not.  Output is fine through the serial uart; I can log into the initial boot (as root) and set up an account,  which I can then use  (through serial uart) when system reboots,  but there is never any output on the PBP, itself.  It doesn't matter whether I have the serial connection plugged into the headphone jack or not.  Are those of you who are succesfully getting output using  serial uart,(i.e. have switch 9 moved from its default position)?  Are you booting from SD?
Thanks for any info/help.
I'm having the same issue. eMMC has the default debian, and I'm trying to boot into the Manjaro image off SD card. I'm too lazy to open it up again to turn on UART to check the console so far, however...
For people with display not turning on problems the newer kernel should fix that (there is a workaround for a missing presence detect line).
What is the correct keyboard layout for Manjaro? (including all the symbol keys)?
(11-09-2019, 04:18 AM)spikerguy Wrote:
(11-08-2019, 08:36 PM)belfastraven Wrote: Question:  Obviously people are getting output on their powerbook screens, but I am not.{...}
There are some users who have reported this. Thank you for reporting it here. I think this have something to do with the new LCD drivers. We have not found anything for this yet, Once we get some lead on this issue then we will be able to get a solution.
(11-09-2019, 02:20 PM)pawlinski Wrote: A kernel update has appeared. The sound began to work. Volume function keys also. WiFi also seemed to be more stable. Thanks to the guys from Manjaro Smile
Given that without display output it's hard to do the upgrade to the kernel that brings display output, could the manjaro arm team make a new preview image that includes the newer kernel ?
Without having an UART cable, the workaround I managed was chrooting into the SD card from Pinebook Pro's default Debian, and running pacman in this chroot.
The LCD output issue is not been fixed in the updated Kernel, The dev's are not able to re-produce it on the developers devices.
Once they're able to find the issue then there will be an updated release.
UPDATE: I hope there will be a new image release tomorrow which should solve the LCD issue. We had someone test the LCD with the updated kernel.
Thank you for all the support & feedback which helps us improve the built.
Manjaro ARM Team.
(11-10-2019, 03:00 AM)brent.thierens Wrote: What is the correct keyboard layout for Manjaro?
I've had success using the plain simple "UK" with the ISO (european) keyboard.
(11-10-2019, 03:00 AM)brent.thierens Wrote: (including all the symbol keys)?
The pine symbol key is simply a "meta" -key (like the Windows key on other keyboard. Or the "tux" key :-P )
The blue FN functions (volume, etc.) are simply multimedia keys (they are sent as volume commands, etc.)
i.e.: everything should work out of the box.
(11-10-2019, 02:54 PM)DrYak Wrote: The blue FN functions (volume, etc.) are simply multimedia keys (they are sent as volume commands, etc.)
If not, copy /etc/udev/hwdb.d/10-usb-kbd.hwdb from the default debian system to the same location of your Manjaro SD.
#19
In the Latest Manjaro Built. Not all Function key works. We have added some Manually but its not all. Manjaro ARM Team is working on getting all the Function keys to work out of the box, but this will require more development, time and testing.
Thank You for all the love and support for Manjaro Linux.
Manjaro ARM Team.
#20
I upgrade my system and I don't have sound, functions keys or wifi... ;(
Did you touch something else?
  Boot Order in Pinebook Pro food 12 19,239 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 6,562 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,263 08-09-2025, 06:53 AM
Last Post: Sb2024
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,691 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,401 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,501 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,688 08-21-2024, 04:17 AM
  Official Debian support moonwalkers 64 124,128 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,783 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,505 03-31-2024, 10:11 AM
Last Post: u974615
