Hello Everyone,
I am please to inform that Manjaro ARM Team have officially released 19.12
Kindly check the Official post of Manjaro Forum.
Manjaro ARM 19.12 released!
Manjaro ARM Preview1 for Pinebook Pro!
manjaro ARM Preview2 is Release
Link: https://forum.manjaro.org/t/manjaro-arm-...=spikerguy
Known Issues:
  • No Bluetooth.
  • Unstable Wifi (might crap out after around 10 minutes) - Fix have been worked out.
  • No audio cards.
  • Brightness and Volume function keys do not work.
  • Does not power off completely from software.
  • Suspend does not work.
  • To show the OEM setup on the XFCE edition, wait until the bootsplash has run for 10-15 seconds, then press
Thanks to @Strit for all his time & effort and @tsys for sharing the Mainline Kernel patches.
Please try it out and share your experience & feedback's. It really helps the developers
Thank You.
Posted from PineBook Pro with Manjaro Linux
Manjaro ARM Team.
This is the correct link...
If we install this and keep our system up to date with pacman, will we automatically get the new fixes or is a clean flash required?
You will get the automagically! Just be sure to reboot after your update
Sent from my iPhone using Tapatalk
Absolutely love it! Runs very smooth and low on resources!
However as long as audio doesn't work not that usable Smile
I'm testing Manjaro on my PBP.
I can't connect to the 5ghz WIFI.
I'm able to see only 2.4 ghz networks.
I tested briefly last night and had issues with the wifi continuing to flake out after applying the powersave workaround and restarting the daemon and/or rebooting. Known issues aside the build seemed to work well, hard to do much with it with 10 minutes of network connectivity though.
Question:  Obviously people are getting output on their powerbook screens, but I am not.  Output is fine through the serial uart; I can log into the initial boot (as root) and set up an account,  which I can then use  (through serial uart) when system reboots,  but there is never any output on the PBP, itself.  It doesn't matter whether I have the serial connection plugged into the headphone jack or not.  Are those of you who are succesfully getting output using  serial uart,(i.e. have switch 9 moved from its default position)?  Are you booting from SD?
Thanks for any info/help.
(11-08-2019, 08:36 PM)belfastraven Wrote: Question:  Obviously people are getting output on their powerbook screens, but I am not.  Output is fine through the serial uart; I can log into the initial boot (as root) and set up an account,  which I can then use  (through serial uart) when system reboots,  but there is never any output on the PBP, itself.  It doesn't matter whether I have the serial connection plugged into the headphone jack or not.  Are those of you who are succesfully getting output using  serial uart,(i.e. have switch 9 moved from its default position)?  Are you booting from SD?
I'm having this problem with Manjaro intermittently. I feel like it works fine for a while then i reboot and the screen never comes on. It does boot, just no screen.
They specifically pointed out that the display drivers are flakey, I'm accounting it to that.
(11-08-2019, 04:16 PM)cristobalhdez Wrote: I'm testing Manjaro on my PBP.
I have tried it and it works fine. I will try to do a more details test this time and get back to you.
(11-08-2019, 05:15 PM)Arglebargle Wrote: I tested briefly last night and had issues with the wifi continuing to flake out after applying the powersave workaround and restarting the daemon and/or rebooting. Known issues aside the build seemed to work well, hard to do much with it with 10 minutes of network connectivity though.
Yes it is just a workaround and not a complete fix. For most people it is working fine with the TLP workaround. We shall find a permanent fix soon.
There are some users who have reported this. Thank you for reporting it here. I think this have something to do with the new LCD drivers. We have not found anything for this yet, Once we get some lead on this issue then we will be able to get a solution.
I think you're right Display drivers seems flakey but we're working on it and should be able to find some solution.
Currently we're working on finding s Wifi & Audio Fix.
Stay connected to get the update's & Thank you for all the feedback's.
Manjaro ARM Team.
  Boot Order in Pinebook Pro food 14 20,143 11-16-2026, 01:09 AM
Last Post: NorrisFByrd
  Window Maker Live for Pinebook Pro vajak 9 6,794 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,445 08-09-2025, 06:53 AM
Last Post: Sb2024
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,867 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,594 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,705 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,927 08-21-2024, 04:17 AM
  Official Debian support moonwalkers 64 125,997 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,967 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,748 03-31-2024, 10:11 AM
Last Post: u974615
