Will purchasing an NVMe SSD noticably improve performance
Question
I've been tinkering with my PBP for the past few days now (mostly with the system monitor open). I'm happy enough with the current performance, but I've been wondering where the primary performance bottleneck lies in the PBP. Is it the eMMC interface? If so, I take it that purchasing an NVMe SSD would noticeably speed things up?
Ben
Maybe not. Currently it wouldn't be a bootable drive. It would appear as a secondary drive.
Sent from my iPhone using Tapatalk
Question
(11-07-2019, 09:38 AM)tophneal Wrote: Maybe not. Currently it wouldn't be a bootable drive. It would appear as a secondary drive.
But surely you could just flash the image to the NVMe drive, and change "root=/dev/mmcblk1p2" in /boot/extlinux/extlinux.conf to "root=/dev/nvme0n1p2"? Then, everything would be running off the NVMe drive
Ben
Ben
Potentially. It was discussed briefly in another thread. I believe the final sentiment of the thread was "we won't truly know until someone tries."
Ben
I have put a NVMe SSD in my PBP.
Toshiba OCZ RC100, 240 GB, m.2 2242: 42mm long. So I could take 3 cm off of the adapter.
All is working very well, no problem with the touchpad.
After starting up the NVMe SSD was mounted and known as /dev/nvme0n1. (Gparted)
I would like to give it a try.
Supply me with detailed instructions s'il vous plaît.
Ben
 Here's what I found when searching it out: https://forum.pine64.org/showthread.php?tid=4971
Not sure if the uboot updates since then allow for booting from NVMe yet, though.
step 4. sudo nano /boot/efi/extlinux/extlinux.conf
Directory /efi/ is missing:
/boot/extlinux/extlinux.conf exists. No problem?
And for me it's impossible to edit extlinux.conf.
Any suggestions?
(11-07-2019, 09:32 AM)Feakster Wrote: Hi,
... but I've been wondering where the primary performance bottleneck lies in the PBP. Is it the eMMC interface? ...
Ben
Hi Ben, please describe in more detail this performance bottleneck you describe above. I am curious about the context of your observation.
Ben
I have nothing to point fingers at in particular. It's just that on several occasions when I've been waiting for the PBP, I've noticed that the processor doesn't appear to be pushed.
Ben
Just to clarify, I'm not saying there's anything wrong with the performance of the PBP. It's become my daily driver, and I'm currently sat happily typing away on the Pine64 forums on it now. However, I have a spare bit of cash for an NVMe drive, and I was curious to know whether it would be worth the investment. Also, from what I've been seeing on Twitter, I get the impression that Manjaro will soon be available on the PBP... An OS reinstall seems like a good opportunity to try an NVMe drive in the PBP.
Ben
What OS did you use? Was there any extra configuration required? I have installed NVME too, but it doesn't appear anywhere, neither in lsblk nor in lspci.
  NVMe drives not detected mattpenn 18 29,906 12-24-2024, 08:54 PM
  NVMe reukiodo 0 2,803 11-18-2024, 09:00 AM
Last Post: reukiodo
  New Working nVME gilwood 1 4,203 11-17-2024, 04:24 AM
Last Post: reukiodo
  NVME problems 2022 / Intel 660p 1TB Starbug 1 5,424 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 5,187 11-28-2022, 12:56 PM
Last Post: dachalife
  NVme intall usage? tkudog 2 6,138 03-04-2022, 01:29 AM
Last Post: Tazdevl
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 4,357 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  NVMe SSD testing methodology halogen 1 5,489 07-22-2021, 05:57 PM
Last Post: calinb
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 10,219 07-09-2021, 08:45 PM
Last Post: moonwalkers
  nvme drive disappears after about an hour of uptime codebreaker 24 58,583 02-09-2021, 11:32 PM
Last Post: dsimic
