12-10-2015, 03:34 PM
has there been any testing to determine average boot up times in Linux and android?
boot times
12-10-2015, 03:41 PM
(12-10-2015, 03:34 PM)mr_ada Wrote: has there been any testing to determine average boot up times in Linux and android? The current boot time for Android Loliipop 5.1.1 build is around 40 seconds and plan on reduce down to 25-30 seconds. For Linux, this highly depends on the build and what type of drivers to bring up, light build should able to boot up on few seconds. In general, Android build is "thicker" than Linux.
12-10-2015, 06:36 PM
(12-10-2015, 03:41 PM)tllim Wrote:(12-10-2015, 03:34 PM)mr_ada Wrote: has there been any testing to determine average boot up times in Linux and android? I guess android wouldn't work for me. I was able to get my galaxy tab 7 down to 19 seconds boot up time in Android (cyanogen mod). Still not acceptable. There was a demo back in 2011 from linutronix that showed a Qt-based app that cold booted up in under 2 seconds. Using ARM9 AT91SAM9G45 @400MHz. Your product has much more power. Check it out: https://youtu.be/rhjS8ZONE74 I'd want this most "slim" linux version to run. |
| PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot | burningkrome | 3 | 7,208 |
05-19-2023, 07:43 AM Last Post: crocspot |
| Pine A64 does only boot with Android 5.1 | Dude | 6 | 11,541 |
07-03-2022, 02:18 PM Last Post: Dude |
| Pine A64+ vs LCD do not boot | DDS | 3 | 11,655 |
02-23-2021, 05:33 PM Last Post: thedu |
Can't boot when SD card inserted | kivox | 5 | 13,678 |
03-15-2020, 06:00 AM Last Post: kivox |
| Boot from HDD via usb | BnEc | 1 | 6,173 |
11-29-2019, 04:39 AM Last Post: evilbunny |
| Pine A64 stuck in boot process | joey | 1 | 5,916 |
05-28-2019, 09:07 PM Last Post: joey |
| Won't power on/boot -- kickstarter A64 2GB | fuzzycuffs | 3 | 10,418 |
02-22-2019, 03:25 AM Last Post: GaryFunk |
| boot loop with lcd plugged in | drock | 0 | 3,718 |
01-09-2019, 01:37 AM Last Post: drock |
| LED flashes for 1 second, board won't boot | Audioslave | 2 | 7,409 |
08-02-2018, 10:28 PM Last Post: tllim |
| short boot time after power-up | bongo | 7 | 17,550 |
10-31-2017, 08:02 AM Last Post: bongo |
