Pine OS on non-PineBook
Dumb question but is it possible to install the OS to another laptop?
(12-04-2018, 09:23 PM)aberrebbi Wrote: Dumb question but is it possible to install the OS to another laptop?
Which OS to which laptop? - the answer is most certainly 'no'
Well, it's possible to install (sort of) Pinebook OSes with, e.g. chroot and qemu-aarch64-user-static onto, say amd64 laptop running amd64 linux and run some programs. But it's probably not really what you want to do, especially because pretty much all ARM software exists on amd64 anyways.
If by "Pine OS" - you meant KDE Neon - yes, you can grab an amd64 iso from there and install it on amd64 laptop (but Neon isn't really a Pinebook OS):
https://neon.kde.org/download
A more correct statement might be, it is all linux software that happens to be compiled for the ARM processor (for use on the Pinebook). Since linux is source code portable, you should have no problem finding compiled versions (of KDE Neon, for example) for the AMD/Intel processors.
The OP might want to give distro watch a look:
https://distrowatch.com/
(12-05-2018, 06:10 PM)Thanks again! cvmiller Wrote: > But it's probably not really what you want to do, especially because pretty much all ARM software exists on amd64 anyways.
  Dead Pinebook - fix it or spare parts? oloturia 2 8,123 03-19-2023, 03:38 PM
Last Post: oloturia
  Broken bottom case of PineBook 14 Mick 1 5,374 02-22-2023, 05:49 AM
Last Post: Mick
  Original 14" Pinebook an Orphan? vdicarlo 2 6,819 01-05-2023, 10:42 AM
Last Post: jezek
  Pinebook Users are a nobody leperotero 13 29,704 09-06-2022, 09:29 PM
Last Post: zapper
  Does anybody repair pinebook pro laptops for a fee? Tsvi Bar-David 0 4,785 09-05-2022, 07:49 PM
Last Post: Tsvi Bar-David
  Pinebook with a broken screen and 2 eMMC's for sale. UK ONLY. frank-zappa 0 5,681 03-08-2022, 10:14 AM
Last Post: frank-zappa
  Pinebook to Pinebook Pro-esque upgrade kit sebboh 5 14,870 08-18-2021, 11:01 PM
Last Post: Corkonian
  new pinebook help ron_burgundy 5 15,815 12-17-2020, 04:54 PM
Last Post: ron_burgundy
  Few questions about flashing to a MicroSD card on the Pinebook Pro SanjevR 6 19,292 12-07-2020, 04:02 PM
Last Post: SanjevR
  TOR Browser on the Pinebook Pro jay3gg 0 6,103 11-16-2020, 01:25 AM
Last Post: jay3gg
