Defective? PCI-E -> SATA card no work good
If you really want a window manager, Bullet64, it turns out i3 will work as of 0.7.9.
1. Install an Ubuntu Bionic minimal image (which you already have)
2. `sudo /usr/local/sbin/install_desktop.sh i3`
3. Uh, learn i3? I'm taking a lot from https://fedoramagazine.org/getting-start...w-manager/
If you are having trouble with PCIe detection and a specific device, I compiled an older mrfixit2001 kernel that works for my device (Silicon Image SiI 3132) whereas the newer kernels do not detect the root PCIe either.
Try the debs.tar.gz here:
https://github.com/digitalsanity/rockchi...-pcie-test
  (real) Mainline U-boot finally works on SPI, boots SATA, throw away your SD cards NOW aleksei 0 12,981 06-21-2025, 06:21 AM
Last Post: aleksei
  How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card jykeith123 1 5,530 11-26-2024, 11:08 AM
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 228,144 09-25-2023, 12:46 AM
Last Post: ChriChri
  Sata HD stopped booting db579 2 5,447 03-11-2022, 03:34 PM
Last Post: db579
  Rockpro64 with PCI FC Card - Not booting (Sometimes) MSteam 1 5,029 10-25-2020, 07:42 PM
Last Post: MSteam
  fan continously runs on kernel 5.8 but I need to use 5. kernel for PCIe sata card GreyLinux 4 10,197 10-20-2020, 10:52 AM
Last Post: GreyLinux
  RockPro64 SSD Expansion Board/SATA Shield as0zial 5 12,994 10-18-2020, 08:05 PM
Last Post: revoman
  4pin Connector for dual SATA m.ekstrom 4 10,299 07-28-2020, 07:07 AM
Last Post: mabs
  micro SD Card Slot Spring not working, Cant boot mjembd 1 5,302 04-16-2020, 12:30 AM
Last Post: mjembd
  Spotify - work arround with librespot-java Helium75 0 4,245 12-08-2019, 06:53 AM
Last Post: Helium75
