Spotify - work arround with librespot-java
Good day everybody Smile
I tried to compile librespot for the rock64 unfortunately it throws me an error that it can't be compiled :
 = note: /tmp/cargo-installPJfUds/release/build/byteorder-e6b6a6b0fb32eb88/build_script_build-e6b6a6b0fb32eb88.build_script_build.d7wzi3u7-cgu.0.rcgu.o: file not recognized: File format not recognized
          collect2: error: ld returned 1 exit status
error: aborting due to previous error
error: could not compile `byteorder`.
warning: build failed, waiting for other jobs to finish...
error: failed to compile `librespot v0.1.0`, intermediate artifacts can be found at `/tmp/cargo-installPJfUds`
I haven't figured out would the problem might be (noob programmer, so to say). I also tried to install the raspberry binary which caused the system to overload - so that didn't work either.
Good news:
I found a project that ported the lib into java :
https://github.com/librespot-org/librespot-java
.... and it works (nearly) perfect. Just install java, set the option mixerSearchKeywords = "default" int the config.toml file .... that's it Smile
Enjoy
Helium
  Spotify kardanadm 6 15,307 03-13-2020, 04:30 AM
Last Post: SamualSS
  Defective? PCI-E -> SATA card no work good unregisteredidiot 11 21,972 02-19-2020, 09:08 AM
Last Post: fysa
  Shadow Game streaming - does it work? korn2017 1 5,408 06-13-2019, 07:30 PM
