Spotify
Hi
I tried many things but couldn't install Spotify.
I found a spotify for Rpi. can we edit it for RockPro64
https://github.com/dtcooper/raspotify
(03-25-2019, 07:15 AM)kardanadm Wrote: Hi
Didn't look closely, but looks like its for jessie, so perhaps you just need to sort of dependency issues? what errors are you seeing?
[edit] You're likely to have an easier time with mopidy (with the spotify plugin).
RockPro64 is very nice SBC, works fine as normal computer. want to use in daily life. but all of my music archive is spotify and I can't live without music!
I tried a lot, but I wasn't successful. web player doesn't even work Smile web player is good enough for me but it doesn't work !!!
Also an application required for Pinobook pro Smile
edit: Yeaa mopidy also happens. I will try to establish, if I succeed I will be very happy.
(03-25-2019, 07:26 AM)Luke Wrote: [edit] You're likely to have an easier time with mopidy (with the spotify plugin).
I installed Mopidy.
I need to install "sudo pip install Mopidy-Mopify" but I can't load anything from the pip repository.
Mopidy-Mopify installation completed. See all the playlists, but the same as Spotify web player. No sound movement does not work. I only see my Playlists Smile
I keep using Android. currently it is the most suitable OS for daily use. Sad
I installed Kodi (17.6) with Synaptic. I've installed Spotify add-ons. I've used this combination on Win10, I don't know why I haven't thought of it before. : P
I'm happy now with "0.8.X images from ayufan; Mate DE"
If you install and use Spotify app successfully, you can consider getting a DRmare Spotify Music Converter to download Spotify music for Rpi or other devices. The DRmare is only for personal use. The DRmare website tells you more about the tool.
  Spotify - work arround with librespot-java Helium75 0 4,134 12-08-2019, 06:53 AM
Last Post: Helium75
