(real) Mainline U-boot finally works on SPI, boots SATA, throw away your SD cards NOW
This is on Arch ARM* or Manjaro installed on RP64. If compiling on amd64 machine, set CROSS_COMPILE variables accordingly.
Build ATF:
git clone --depth=1 -b v2.13.0 https://github.com/ARM-software/arm-trusted-firmware.git make -j $(nproc) CC=gcc PLAT=rk3399 bl31
Build U-boot:
git clone --depth=1 -b v2025.04 https://source.denx.de/u-boot/u-boot.git export BL31=/path/to/built/bl31.elf make mrproper && make rockpro64-rk3399_defconfig make menuconfig
Here are the changed variables in .config, but don't just copy them to your .config - search for them in menuconfig and change there, the menu will take care of dependencies.
CONFIG_BOOTDELAY=20 CONFIG_BOOTCOMMAND="bootflow scan -lbm" CONFIG_CMD_ERASEENV=y CONFIG_CMD_NVEDIT_LOAD=y CONFIG_NO_NET=y CONFIG_BAUDRATE=115200 CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="usb start" CONFIG_PREBOOT_DEFINED=y make -j $(nproc)
Writing to SD card first to test it (from doc/README.rockchip in U-boot source, "Option 3: Package the image with TPL"):
dd if=idbloader.img of=/dev/sdX seek=64 dd if=u-boot.itb of=/dev/sdX seek=16384 sync
Flashing to SPI is much simpler nowadays, see doc/board/rockchip/rockchip.rst in U-boot source. Create a partition with FAT filesystem on the same SD card, place u-boot-rockchip-spi.bin on it, reboot, get to U-boot cmdline and:
sf probe load mmc 1:1 $kernel_addr_r u-boot-rockchip-spi.bin sf update $fileaddr 0 $filesize
If sf probe returns an error or booting from SPI fails, short pins 23 and 25 on GPIO to temporarily disable SPI. After booting disconnect them again and erase SPI to at least get SD boot working.
U-boot environment section on SPI might be empty, broken or contain wrong variables. To get default environment for installed version of U-boot, remove situational partitions variable and save the environment to SPI, run in U-boot cmdline:
env default -a env delete partitions env save
Then create EFI partition on SATA disk and proceed like with a regular UEFI machine. U-boot from SPI will also scan SATA partitions for extlinux/extlinux.conf, boot.scr and other U-boot-specific boot configs.
* On Arch, pacman -U these 3 pkgs from Manjaro (choose a mirror close to you) to build ATF:
https://mirror.truenetwork.ru/manjaro/ar...kg.tar.zst
PS Screw this forum software inserting copious newlines on every press of preview button.
  enble boot after power loss/restore dkebler 18 30,613 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 228,456 09-25-2023, 12:46 AM
Last Post: ChriChri
Bug Broken boot: What am I missing? mkosarek 1 4,625 09-08-2023, 08:14 AM
  Unable to boot Armbian on new RockPro64 mooseball 5 13,981 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 14,279 05-18-2023, 10:46 AM
  u-boot locked on pine64pro ljones 1 4,675 09-06-2022, 10:32 AM
Last Post: ljones
  Cannot get my board to boot deutschlmao 11 20,149 09-05-2022, 04:23 PM
Last Post: ljones
  U-BOOT Tutorial hazz 0 3,617 07-19-2022, 10:48 PM
Last Post: hazz
  Installation Debian on emmc: which U-Boot and where? vongillus 3 8,146 07-02-2022, 09:24 AM
Last Post: dkebler
  ROCKPRO64 PCI SSD SD-boot Install pspgarret 0 3,749 06-09-2022, 10:56 AM
Last Post: pspgarret
