Clusterboard Pinouts
I made an overview of the GPIO header for the nodes while playing with my Clusterboard prototype, maybe it helps others working on this...
Maybe someone can verify this against the schematics again...
(02-15-2018, 05:36 AM)xalius Wrote: I made an overview of the GPIO header for the nodes while playing with my Clusterboard prototype, maybe it helps others working on this...
Appreciates and thanks.
Thanks for doing this. Is there no 3v3VCC? If the I/O's are all 3v3 then the lack of a 3v3 pin seems strange?
The pins are numbered differently on the board.  One row is 1-10, the other is 11-20.
(03-20-2019, 04:47 PM)AZClusterboard Wrote: The pins are numbered differently on the board.  One row is 1-10, the other is 11-20.
Huh
Depends on your definition of row. Is it a 10 column, 2 row or a 2 column, 10 row header? Both xalius and I obviously think it's a 10 row, two column header pinout, with pins 1 and 19 marked so you don't get it back-to-front :-P If you have the board oriented so you the ethernet jack is at the back, the document matches the pinout. I would have done it the other way, only because I tend to have the usb ports and on-board LEDs facing me for visibility.
.jpg   clusterboard v2.2 gpio header.jpg (Size: 81.72 KB / Downloads: 939)
  Managed Ethernet switch on the Clusterboard dsimic 6 17,162 01-16-2024, 02:05 AM
Last Post: hazcam
  Selling Clusterboard + 4 sopine xblack86 7 14,736 09-26-2022, 03:09 AM
Last Post: poVoq
  clusterboard availability? linear 1 5,622 07-17-2022, 06:44 AM
Last Post: poVoq
  Clusterboard not getting IP address after network fix Norlark 14 28,719 08-30-2021, 05:00 PM
Last Post: poVoq
  When would be the Clusterboard back on stock? __kzl__ 5 12,411 08-16-2021, 03:52 AM
Last Post: poVoq
  Schematics for customising the Clusterboard TechDragon 0 5,723 05-25-2021, 10:28 AM
Last Post: TechDragon
Information Clusterboard Guide AZClusterboard 9 35,898 04-06-2021, 06:32 AM
Last Post: poVoq
Brick Clusterboard CAD drawings TeaPack 1 7,088 03-31-2021, 01:38 PM
Last Post: Pine
  New Clusterboard Setup wargfn 5 14,723 01-01-2021, 10:10 AM
Last Post: poVoq
  Clusterboard does not even turn on? poVoq 3 11,035 08-15-2020, 07:31 AM
Last Post: poVoq
