Compiling and installing Wifi driver
Hey guys, Linux newbie here. I got my Rock64 running with the new ubuntu image (xenial-mate-rock64-0.5.5-93-arm64.img.xz) and I'm trying to compile the Wifi+BT driver for my combo USB dongle. I cloned the git repo (Git) and tried compile it with "sudo make", but I keep getting an error. Anybody here can help me out?
rock64@rock64:~/.git/rtl8723bu$ sudo make
[sudo] password for rock64:
make ARCH=aarch64 CROSS_COMPILE= -C /lib/modules/4.4.77-rockchip-ayufan-93/build M=/home/rock64/.git/rtl8723bu  modules
make[1]: Entering directory '/usr/src/linux-headers-4.4.77-rockchip-ayufan-93'
Makefile:634: arch/aarch64/Makefile: No such file or directory
make[1]: *** No rule to make target 'arch/aarch64/Makefile'.  Stop.
make[1]: Leaving directory '/usr/src/linux-headers-4.4.77-rockchip-ayufan-93'
Makefile:321: recipe for target 'modules' failed
make: *** [modules] Error 2
I already tried installing the linux-headers from ayufans repo with dpkg, didn't help. The same command works on my normal ubuntu PC.
`arm64` should be an `ARCH`.
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
I don't really know what I'm doing but I changed this line in the Makefile from
SUBARCH := $(shell uname -m | sed -e s/i.86/i386/ | sed -e s/ppc/powerpc/ | sed -e s/armv.l/arm/)
ARCH ?= $(SUBARCH)
to
SUBARCH := "arm64"
ARCH ?= $(SUBARCH)
and I got a different error while make:
make ARCH="arm64" CROSS_COMPILE= -C /lib/modules/4.4.77-rockchip-ayufan-93/build M=/home/rock64/.git/rtl8723bu  modules
 CC [M]  /home/rock64/.git/rtl8723bu/core/rtw_cmd.o
In file included from ./arch/arm64/include/asm/sysreg.h:25:0,
                from ./arch/arm64/include/asm/cputype.h:89,
                from ./arch/arm64/include/asm/cachetype.h:19,
                from ./arch/arm64/include/asm/cache.h:19,
                from include/linux/cache.h:5,
                from include/linux/printk.h:8,
                from include/linux/kernel.h:13,
                from include/linux/list.h:8,
                from include/linux/preempt.h:10,
                from include/linux/spinlock.h:50,
                from /home/rock64/.git/rtl8723bu/include/osdep_service_linux.h:24,
                from /home/rock64/.git/rtl8723bu/include/osdep_service.h:40,
                from /home/rock64/.git/rtl8723bu/include/drv_types.h:32,
                from /home/rock64/.git/rtl8723bu/core/rtw_cmd.c:22:
./arch/arm64/include/asm/opcodes.h:5:43: fatal error: ../../arm/include/asm/opcodes.h: No such file or directory
compilation terminated.
scripts/Makefile.build:258: recipe for target '/home/rock64/.git/rtl8723bu/core/rtw_cmd.o' failed
make[2]: *** [/home/rock64/.git/rtl8723bu/core/rtw_cmd.o] Error 1
Makefile:1424: recipe for target '_module_/home/rock64/.git/rtl8723bu' failed
make[1]: *** [_module_/home/rock64/.git/rtl8723bu] Error 2
Consider updating this kernel source to include this driver: https://github.com/ayufan-rock64/linux-k...kchip_wlan as part of the compilation.
Releases:
Buy me a Beer
I'm sorry I didn't quite understand what I should do now.
Same issue here. How can we update kernel source..?
Trimis de pe al meu Nexus 6 folosind Tapatalk
Lexstar & skyway, ayufan has done some tutorials on how to build an image, mostly for the android image but the concepts are the same. i don't have a link but try searching with "ayufan build android image for pine64 on github" and see if you get the link. plus you might want to read some basic howtos & tutorials on build images for background, but be prepared it has rather steep learning curve and is not for the intellectually challenged nor lazy.
One of the SBCs I own is Odroid XU4 made by Hardkernel and I found that they provide a very good online documentation. Maybe you can take some ideas from their step-by-step guides on how to compile its kernel.
Here is the link https://wiki.odroid.com/odroid-c2/softwa...ing_kernel
Hopefully this helps.
neah, didn't help, way too much for me to understand, maybe someone will post the commands needed for this to work. tried, and tried, and tried again. nothing. Spent like 5 hours, but gave up eventually...
So, if anyone solved the issue, can you tell us how you did it?
Not sure why there isn't more community input to the Wiki.
The current wiki is extremely sparse and much of the forum is lost in time, like forums do.
Collaboration could assist the few in many areas and it is a shame that doesn't seem to be employed.
  Installing DietPie on Rock64 and set 1280x1024 resolution Dape97 2 6,225 05-26-2020, 07:20 AM
Last Post: Dape97
  on-board ethernet driver michaelanburaj 0 3,040 03-26-2020, 12:01 PM
Last Post: michaelanburaj
  Ayufan Debian Stretch Openmediavault 4 5G Wifi Not Connecting Poincare 0 3,508 03-26-2019, 07:28 PM
Last Post: Poincare
  Can't connect to wifi on a Rock64 SuperSaiyanCaleb 2 6,661 12-18-2018, 11:51 PM
Last Post: SuperSaiyanCaleb
Lightbulb Wifi problem Nether494 13 27,799 11-28-2018, 01:48 PM
Last Post: Nether494
  8812au wifi driver OS pane 9 18,531 11-19-2018, 02:46 AM
Last Post: pane
  Freeze/reboot/errors when compiling - unable to make - reproducible and not isolated jovval 2 6,217 10-02-2018, 08:10 AM
Last Post: jovval
  WiFi on Armbian problem scalextrix 14 28,623 09-08-2018, 01:13 AM
Last Post: scalextrix
  If installing free software system which devices will not work? heocb 6 11,143 08-17-2018, 09:42 AM
Last Post: heocb
  Rock64: Debian root fs on software RAID1 of eMMC and microSD - is installing it the s jovval 2 6,082 08-03-2018, 12:33 PM
Last Post: jovval
