About the Pinebook - What to expect
I just bought a couple of matching car adapters from AliExpress with 5V/3A and the barrel plug...
https://www.aliexpress.com/snapshot/0.ht...2611430732
Edit (pfeerick): I think you meant to give this link, the other one was the link to your order page! Wink https://www.aliexpress.com/item/Power-Ad...30732.html
(06-19-2017, 09:32 AM)xalius Wrote: I just bought a couple of matching car adapters from AliExpress with 5V/3A and the barrel plug...
I'll be curious to know how you go... I dubious about stability of those small car converters, but then, again, I'm used to the power train from 1970/1980s vehicles, which would put the 10v to 40v that the automotive grade power regulators are supposed to handle to the test a times :-O (crazy wiring harnesses, long leads where they really weren't needed and trusty alternator livening things up, and zero power filtering... cigarette socket was exactly that... for cigarettes Wink )
Me too;   That's why I always put a PI filter on mine;  the CPT converter works well (filtered).  It really comes down to what kind of ripple the converter has (also spikes, other spurious noise) and whether the PI filter is designed effectively to remove the ripple.  It also depends on the vehicle being used;  some vehicles are inherently noisier than others;  I had a Ford pickup (F150) a few years back that you could hear (from EFI) coming two blocks away;  its alternator was fierce!. My Chevy 1500 Silverado today is really pretty good; very quite.
I've received my pineboox 14" earlier this week and I'm loving it! I removed the default desktop environment and use lxqt instead. However, I am not able to change the screen brightness. Does anyone have any advice on how to change the screen brightness?
I am using mate on my 11" and an panel applet does the trick
Gesendet von meinem Xperia Z3C mit Tapatalk
(06-23-2017, 08:43 AM)schultheiss Wrote: Hello,
Dont know the DE, but I read though a few posts over at manjaro and it seems there should be a brightness slider under power settings applet (battery ?). Otherwise you'll have to do it from terminal ...
Here's what happens when I try to set the brightness via the console:
pine64 in ~ ➤ xbacklight -50
No outputs have backlight property
Any ideas?
P.S: why can I only post one message per day? It's not like this forum has thousands of new subscribers every day and you need to limit how many messages they can post to avoid chaos?
Any ideas?
Brightness settings are in /sys/class/backlight/lcd0
Perhaps reading this will help.
Regarding your question about limits to posting - read forum rules. In short, you will be soon able to post as much as you please ... 3 day rule to prevent spam.
(06-24-2017, 12:56 PM)Luke Wrote: Brightness settings are in /sys/class/backlight/lcd0
Hi again, thanks for the link, I'm able now to set the brightness via the terminal!
As for the rule, I'll be patient then.  Angel
Hello Luke!!!
Fantastic effort your guys put into this!!! Just love it!!!
Would it be possible to elaborate into pine64 vs pinebook PCB?
Thanx
//Fred
  Dead Pinebook - fix it or spare parts? oloturia 2 7,615 03-19-2023, 03:38 PM
Last Post: oloturia
  Broken bottom case of PineBook 14 Mick 1 4,932 02-22-2023, 05:49 AM
Last Post: Mick
  Original 14" Pinebook an Orphan? vdicarlo 2 6,240 01-05-2023, 10:42 AM
Last Post: jezek
  Pinebook Users are a nobody leperotero 13 27,928 09-06-2022, 09:29 PM
Last Post: zapper
  Does anybody repair pinebook pro laptops for a fee? Tsvi Bar-David 0 4,432 09-05-2022, 07:49 PM
Last Post: Tsvi Bar-David
  Pinebook with a broken screen and 2 eMMC's for sale. UK ONLY. frank-zappa 0 5,317 03-08-2022, 10:14 AM
Last Post: frank-zappa
  Pinebook to Pinebook Pro-esque upgrade kit sebboh 5 13,987 08-18-2021, 11:01 PM
Last Post: Corkonian
  new pinebook help ron_burgundy 5 14,981 12-17-2020, 04:54 PM
Last Post: ron_burgundy
  Few questions about flashing to a MicroSD card on the Pinebook Pro SanjevR 6 18,355 12-07-2020, 04:02 PM
Last Post: SanjevR
  TOR Browser on the Pinebook Pro jay3gg 0 5,742 11-16-2020, 01:25 AM
Last Post: jay3gg
