How is the battery Supposed to be mounted in the PlayBox enclosure?
I figured out the rest, but the battery seems to be a mystery. It doesn't fit under the extra panel that mounts on the side of the case opposite the card. Is supposed to be slid under and held in place by the board itself? Double sided taped to that panel?
Any suggestions?
I would use velcro circles to mount the battery in a convenient open space.
Shy
(02-05-2017, 11:15 PM)MarkHaysHarris777 Wrote: I would use velcro circles to mount the battery in a convenient open space.
Shy
I use the Velco tape method.
  Playbox with DAC llungster 0 5,040 04-02-2019, 09:02 AM
Last Post: llungster
  playbox case ribbon cable too short pinoosh 7 20,260 02-22-2019, 03:24 AM
Last Post: GaryFunk
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 32,800 10-12-2018, 03:08 PM
Lightbulb Perfect ABS Plastic Server Enclosure from Radio Shack MarkHaysHarris777 14 51,762 09-11-2017, 11:39 AM
Last Post: stuartiannaylor
Information Giving the Pine a trunk, a Playbox pedestal tommypine 7 17,130 07-16-2017, 01:51 AM
Last Post: selina3
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 10,583 06-17-2017, 01:29 AM
Last Post: pfeerick
  playbox and camera jpfaubert 1 6,692 03-07-2017, 12:51 AM
Last Post: MarkHaysHarris777
  Nostalgic enclosure VHS carlo318 4 12,972 03-05-2017, 04:56 PM
Last Post: carlo318
  Enclosure for flush-mounting the 7" touchscreen Learnincurve 9 21,234 02-07-2017, 08:45 PM
Last Post: Bluphire
  Official C4 Labs LCD Enclosure *UPDATED WITH ASSEMBLY VIDEO* Bluphire 12 39,242 01-06-2017, 03:15 AM
Last Post: Learnincurve
