Android 5.1.1 TV (old-stable, no longer maintained)
Use something like: https://www.apkmirror.com/ and install them with ES Explorer (sideload).
Homepage: https://ayufan.eu
Releases:
Rock/Pro 64/Pinebook Pro: Linux; Chromium OS
So/Pine A64/Pinebook: Linux; Android 6.0; Android 7.1
Buy me a Beer
From what o have read, they sideload it
I have this Android 5.1.1 version running on my A64.
When using youtube or other media streaming app, sometimes the image turns weird as in purple yellow, sometimes after some seconds the image restores to normal, sometimes I have to switch input on my tv and then back again to get image.
Is 5.1.1 known for this? Looks like hdcp hdmi issue of some sort? First I had this on my HDMI switch, but also when direct on my TV.
Could the Power adapter play a role?
I will try Android 6 later to test.
(01-25-2018, 07:40 AM)renatox Wrote: Hi,
What type of power supply that you are using? Please make sure is 5V 2A type. From de4scription, should not be HDCP issue.
If anyone's still out there, could you help me with this? I'm trying to write the image to a 64 GB card on my Mac but the writing process makes a tiny BOOT partition, installs the OS successfully in there and basically discards the rest of the space. I tried partitioning first and then writing to a small partition but that doesn't work either. Sad
  Need help compiling android for pine a64 + YeeticusMaximus22 2 2,777 08-20-2026, 08:45 AM
Last Post: ahegarosib97
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 613,054 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 50,604 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 32,261 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,807 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 14,400 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,680 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,830 07-15-2019, 08:29 PM
  Issues with SD Card and Running Android Twistedx 0 7,613 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 163,509 02-10-2019, 07:44 PM
Last Post: mmmarcus
