Android 6.0 Tablet and TV (release candidate, maintained)
#91
(12-17-2016, 01:34 PM)Nittola Wrote: After I burned the image (6.0 TV) on the SD and then put it on the Pine64 (2 GB), the red led lights for some seconds and then turn off. Tried several times to turn on, but I obtain the same result everytime. No problem with Android 5.1.1. Possibly soultions?
have you tried unplugging power cable once and replugging it in?
#92
(12-17-2016, 05:16 PM)ayufan Wrote: Nittola: I think that you have some problem with your install, as I did install downloaded image and it works correctly. How do you see that it is not working?
So, I tried to replug the power cable and it worked, Android started, but I can only move the mouse, the left click doesn't work. I turn it off, and I can see that the Pine doesn't start if I turn it on from the power button. I have to replug the cable every time. I'm reburning the image and see if there are differences
#93
Power controls doesn't work correctly as there's something broken with the board wake up sources.
Homepage: https://ayufan.eu
Releases:
Rock/Pro 64/Pinebook Pro: Linux; Chromium OS
So/Pine A64/Pinebook: Linux; Android 6.0; Android 7.1
Buy me a Beer
#94
(12-18-2016, 06:57 AM)ayufan Wrote: Power controls doesn't work correctly as there's something broken with the board wake up sources.
I burned the non-TV ROM and except VVVVID (a legaly streaming platform) all seems to work (I had problems with this app even with 5.1.1.). I don't think the board is broken, because as I said no problems with 5.1.1. and neither with 6.0 for now.
#95
If you long hold the power button until the red LED goes out, you do not need to pull the plug to power back on. Just press and hold the power button until you see the red LED turn on and then brighten up once.
#96
Hi all,
thanks a lot for your work!!
In these months I tried always the android TV  7.0 and it work fine even if I have problem with DRM schema
Now I want to try the 6.0 to verify if it was more stable as stated by ayufan but I'm faciing some problems
I tried android-6.0-pine-a64-tv-v1.0.2-r21.img.gz
[url=https://github.com/ayufan-pine64/android-6.0/releases/download/1.0.2/android-6.0-pine-a64-tv-v1.0.2-r21.img.gz][/url]The image start but it is very slow and reboot when I try to setup google account.
I have PINE64+ card with 2 G  and wifi dongle.
I'm using the wired connection so I tried to switch off wifi , but I donìt know if there known problem with an hw setup like mine with also the dongle wifi
Are there other guys that have the same problem with 6.0 version.
I tried many 7.0 versions but I don't note the same problems
Thanks a lot
#97
sriva63: use different SD card.
Releases:
Buy me a Beer
#98
so i was have trouble getting the image to load. my pine would turn on for a few seconds then power off. (power light lights for a few seconds, monitor flickers a bit, the power light goes off) I have my pine in the playbox with the lcd screen attached. i went into the config file and enabled the lcd, then the thing booted with BOTH lcd and my monitor.could it be the lcd screen being plugged into my PINE was giving me the hassle with this image? I'll test more later but still great this image works Smile THANKS!
#99
Question
Hi @ayufan, thank you for all your hard work on this OS, I really appreciate it!
I am trying to set up a couple of these boards for family to watch Netflix with, and Android TV 6 is the one I think will be best for now. It seems to be working well, and I was hoping to ask you two questions?
1. I believe we have to use the Netflix Android app (not the Android TV app) and so I have installed this, however it is hard to navigate with the Pine IR remote, as not all areas of the screen on the Netflix app can be accessed. For example, I don't seem to be able to choose a specific episode of a show to watch. Does this mean I should use a keyboard or mouse with this app? Or is it possible that the Android TV version of the Netflix app will work on the Pine64 in future?
2. I have noticed that the onscreen keyboard (I believe it is called the 'leanback' keyboard?) is a bit wrong. I think it might be slightly too large? I have uploaded some pictures (links below), hopefully you can see that the highlight circle is not properly over the letters (it rests over the 'search' button OK) and the bottom row of keys is not fully shown. Is this a bug, or something with my setup? (I am currently using it on a PC monitor, resolution 1920x1080@60Hz, on the 2GB Pine64 with your Android TV 6.0.0 v1.0.2 build 21 version.)
Picture 1 - selected 'd' key with the IR remote
Picture 2 - selected 'space bar' with the IR remote
Picture 3 - selected the 'search' button with the IR remote
Picture 4 - selected the 'p' key with the IR remote
Thank you for any advice you can offer, and thank you again for enabling this functionality for our Pine boards! Smile
(12-18-2016, 11:13 AM)Bluphire Wrote: If you long hold the power button until the red LED goes out, you do not need to pull the plug to power back on. Just press and hold the power button until you see the red LED turn on and then brighten up once.
It works, but it's not dangerous to do this everytime? With 5.1.1. I used only the button for doing everything, even closing (like a normal Android).
  Need help compiling android for pine a64 + YeeticusMaximus22 2 2,618 08-20-2026, 08:45 AM
Last Post: ahegarosib97
Shocked Remote for Android? liodra 18 50,213 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 32,047 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,690 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 14,255 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,569 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,751 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 409,361 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 7,513 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 162,559 02-10-2019, 07:44 PM
Last Post: mmmarcus
