Android 5.1.1 TV (old-stable, no longer maintained)
(10-08-2016, 03:43 AM)ayufan Wrote: xtcrefugee: I do not plan to work on 5.1.1. Please use 7.0 it has everything, expect DRM support.
If you need Gapps on 5.1, you can sideload them from OpenGapps.org.
But we can't use OpenGApps without a working recovery. Nether the 5.1.1 or 7.0 non-tv releases appear to have a working one. If I modify uEnv.txt to use ramdisk-recovery.img I just get a black screen on both. That means no gapps on 5.1.1 and we can't fix the lack of root on 7.0 Sad
I hope you're able to fix either this or the 7.0 release, working gapps and root is pretty important to most people.
OK, sorted it in the end! Big Grin
You can install Open GApps without a recovery using FlashFire. The Google one-time setup didn't trigger for me after installation, but it does if you manually format the data partition afterwards using GParted. No Google Play authentication problems this way either, unlike PINE's own version of 5.1.
(10-07-2016, 10:57 AM)ayufan Wrote:
Quote:OK so can I manually install them!? Or it is impossible?
You can't. It requires google approved device. Pine is not such device.
Crap. I'll use it without cast ! Great development anyway ! Smile
Regarding hevc / h.265:
10bit files, yuv420p10le(tv) files are not playing.
I am able to play yuv420p(tv) encoded h.265 files just fine.
is yuv420p10le(tv) not supported in the hardware?
Thanks!
(10-21-2016, 05:45 PM)i420 Wrote: Regarding hevc / h.265:
Thanks!
I have 4 orange pi's that have the H3 chip as well as 2 pine64's.  It's my understanding that they used the work done on the H3 chips to get the pine64's working.  If that is true then 10 bit HEVC will not be working because it is not supported by the H3 chips.
Thanks!
The 10bit HEVC not support in hardware on Allwinner A64 and H3 SoC.
Hello
Can someone post the the repo init command line used to download the sources
I have tried this
repo init -u https://github.com/ayufan-pine64/manifest.git -b master
output:
Get https://gerrit.googlesource.com/git-repo/clone.bundle
fatal: unable to access 'https://gerrit.googlesource.com/git-repo/': Failed to connect to gerrit.googlesource.com port 443: Connection timed out
or
output:
error: RPC failed; result=7, HTTP code = 0
fatal: The remote end hung up unexpectedly
on both rerun command
output:
remote: Finding sources: 100% (32/32)
remote: Total 32 (delta 12), reused 32 (delta 12)
Unpacking objects: 100% (32/32), done.
From https://gerrit.googlesource.com/git-repo
   82f6798..b881d22  master     -> origin/master
Get https://github.com/ayufan-pine64/manifest.git
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
curl: (22) The requested URL returned error: 404 Not Found
Server does not provide clone.bundle; ignoring.
fatal: Couldn't find remote ref refs/heads/master
Unexpected end of command stream
fatal: cannot obtain manifest https://github.com/ayufan-pine64/manifest.git
Fetch the default branch, not the master.
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
(11-07-2016, 04:48 PM)ayufan Wrote: Fetch the default branch, not the master.
Then how i do using repo to get a list of the branches?
I have look for this in repo docs and have no luck.
what would be the default branch if not master?
Thank you, Daniel
how do I how do I limit lan to 100 mbit
  Need help compiling android for pine a64 + YeeticusMaximus22 1 836 12-13-2025, 09:23 AM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 555,110 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 44,893 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 28,532 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 11,225 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 12,518 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 9,252 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 5,869 07-15-2019, 08:29 PM
  Issues with SD Card and Running Android Twistedx 0 6,610 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 148,665 02-10-2019, 07:44 PM
Last Post: mmmarcus
Users browsing this thread: 39 Guest(s)
