Getting z-wave module working under ubuntu
I'm trying to get the z-wave module working under Ubuntu/Domoticz, however up until now I've not succeeded in this. Does anybody have any pointers or directions to information about how to get the z-wave module up and running (under Ubuntu/Domoticz)?
(10-19-2016, 03:53 AM)marcosti Wrote: Hi,
Domoticz only support Z-Wave USB Dongle(/dev/ttyACM0). I tested domoticz with Z-Wave USB Dongle, it working well.
Pine64 Z-Wave module running on bus Z-wave(/dev/ttyS2)
If you using Bus Z-Wave, you can try to use  openHAB
Link #1
Link #2
Link #1
Link #2
"Only support USB dongle"? Where did you get that from?
Domoticz can be run on the RPi with the Razberry Z-wave module so why shouldn't a similar module work? On the RPi you only need to add a tty symlink (don't remember which direction).
I haven't had time to try it yet myself yet but here's a guide for the Razberry: http://www.vesternet.com/resources/appli...AjMOoZeCEd
Backer #16374 - KS funded January 23rd 2016 - Backerkit funded on March 10th 2016 - BOARD RECEIVED ON JUNE 29th - BACKERKIT ORDER FULFILLED ON SEPT 8th
Link #1
Link #2
Hi bontera,
Thanks for pointing out this. I just get my bus Z-Wave and tested it working.
Running command below:
ln -s /dev/ttyS2 /dev/ttyACM0
Then restart your domoticz, you will able add the z-wave module into it.
Link #1
Link #2
Hi bontera,
Okay, I've figured it out, thanks for all your suggestions!!
The way I managed to have the bus Z-Wave working is doing the following:
1. Create the file /etc/udev/rules.d/10-tty.rules, and add the following (copy the complete line, including the quotes and all);
KERNEL=="ttyS2", SYMLINK+="ttyACM0"
This will make sure that every time you reboot your Pine64, the symbolic link is re-established under the /dev-directory. This is needed since all entries in the /dev-directory are recreated on each boot. So, instead of manually creating a symbolic link each time after the Pine64 boots up, have the udev-rules take care of that for you!
2. make sure that you use beta-releases of Domoticz (under Setup->Settings). Otherwise you will not have the option to select 'OpenZWave USB'.
3. reboot your Pine64, and go to Setup-Hardware and register an OpenZWave USB component, using port '/dev/ttyACM0'
That's it, this enables your bus ZWave module.
(10-20-2016, 02:52 PM)marcosti Wrote: Okay, I've figured it out, thanks for all your suggestions!!
That's great, I'm happy to help.
(10-20-2016, 02:52 PM)marcosti wrote: Wrote: Okay, I've figured it out, thanks for all your suggestions!!
From the above, I got the impression Domoticz requires the device as /dev/ttyACM0.
I had an issue there, as I have a real serial USB device (RFlink on Arduino Mega) and the Ubuntu USB driver wants to give it device name /dev/ttyACM0
And you can't have 2 devices with same name.
Effectively, the link got overwritten when I connected the RFlink, disabling the communication with the Zwave device
After a bit of fiddling and looking through the Domoticz code to see where the hard code /dev/ttyACM0 was, I found that Domoticz actually does NOT require the name to be /dev/ttyACM0 at all. Anything starting with /dev/ttyACM will be accepted.
So I changed the file /etc/udev/rules.d/10-tty.rules into:
KERNEL=="ttyS2", SYMLINK+="ttyACMZwave"
Now I have BOTH the RFlink (running at real /dev/ttyACM0 port) and the Zwave module (running via symlink device /dev/ttyACMZwave) side by side.
This will not create a conflict, as the ubuntu driver adds numbers behind the /dev/ttyACM name
Might be of help to others...
  USB adapter to eMMC module not recognized danril 0 3,319 11-25-2022, 04:16 AM
Last Post: danril
  SOQUARTZ Compute module W does not fit Raspberry Pi CM4 dev board ihab 0 3,492 10-06-2022, 08:46 PM
Last Post: ihab
  Reformatting postmarket os with ubuntu touch mackdaddy67 6 16,917 09-11-2020, 12:41 AM
Last Post: SwordfishII
  Ctrl + Shift + Tab not working in Firefox Bolitoglossa 2 7,302 08-21-2020, 04:05 AM
Last Post: Bolitoglossa
  Input not working after a forced shutdown dic1911 1 5,840 12-24-2018, 07:45 PM
  Any success working with OpenCV on the PineA64? Tonny91 0 3,895 10-16-2018, 09:16 PM
Last Post: Tonny91
  Sopine A64 doesn't boot ubuntu stixcher 5 12,702 12-03-2017, 11:05 AM
  Pine64 Ubuntu Mate No Sound adamjedgar 3 11,164 11-06-2017, 02:53 AM
Last Post: Luke
  Mini-Tutorial to get a linux Desktop GUI working on Pine64+ speedro86 15 39,664 04-05-2017, 01:45 PM
Last Post: speedro86
  RESOLVED - LCD screen not working, HDMI does asuras 10 24,747 04-02-2017, 08:12 AM
Last Post: Luke
