Android 5.1.1 TV (old-stable, no longer maintained)
#91
Quote:Hello again Is it possible to have .zip file without .gz extension?? Cuz I've tried several times but never had a pass through blank screen but when I downloaded android 7 build from pine wiki page that file is .zip and runs like charms.
It will not help if it doesn't work for you.
#92
Ok thanks will try to convert that file and try againSmile
#93
If you want help I need to see what is printed on UART from Pine.
#94
(09-16-2016, 03:38 PM)ayufan Wrote: If you want help I need to see what is printed on UART from Pine.
Actually I'm new to these things so don't know what UART is? Is it some kind of cable? I'll google it and let you know.
#95
UART is a proper name for 'serial', so what Ayufan is asking for you is for you to check / give the output that comes out of the serial console. To access this, grab yourself either this if you're in the US (as adafruit is worth supporting), or probably this if you're anywhere else (as shipping from the US is an arm and a leg). You plug three of the four wires into the pine64, plug it into a computer, and then with some software like Putty, you can see what the output messages are. Once you have the adaptor, someone can walk you through connecting it and setting it up.
#96
Sumeet.GiLL: https://linux-sunxi.org/Pine64#Serial_port_.2F_UART
#97
(09-17-2016, 02:58 AM)pfeerick Wrote: UART is a proper name for 'serial', so what Ayufan is asking for you is for you to check / give the output that comes out of the serial console. To access this, grab yourself either this if you're in the US (as adafruit is worth supporting), or probably this if you're anywhere else (as shipping from the US is an arm and a leg). You plug three of the four wires into the pine64, plug it into a computer, and then with some software like Putty, you can see what the output messages are. Once you have the adaptor, someone can walk you through connecting it and setting it up.
Cheers mate??
(09-17-2016, 03:36 AM)ayufan Wrote: Sumeet.GiLL: https://linux-sunxi.org/Pine64#Serial_port_.2F_UART
Cheers ayufan ?? I'll check it out as soon as I get home. Thnx
#98
Hello, I am a bit late to the party but love the work you are doing here.
Is this O/S capable of surround sound using my receiver? I currently have this installed and am using plex, I was/am hoping that surround sound is possible. I enabled pass through in plex but I believe I am only getting stereo sound as is the case in the other android (not TV os) builds.
Sent from my SM-G920W8 using Tapatalk
#99
methvenc: It's limited to what other builds do offer.
Homepage: https://ayufan.eu
Releases:
Rock/Pro 64/Pinebook Pro: Linux; Chromium OS
So/Pine A64/Pinebook: Linux; Android 6.0; Android 7.1
Buy me a Beer
Finally got working Android 5.1 img
Kudos to ayufan for making this build and cheers pfeerick for helping out mate.
Happy days now
  Need help compiling android for pine a64 + YeeticusMaximus22 2 2,883 08-20-2026, 08:45 AM
Last Post: ahegarosib97
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 615,447 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 50,847 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 32,446 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,888 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 14,522 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,769 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,885 07-15-2019, 08:29 PM
  Issues with SD Card and Running Android Twistedx 0 7,689 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 164,235 02-10-2019, 07:44 PM
Last Post: mmmarcus
