Android 5.1.1 TV (old-stable, no longer maintained)
ChromeCast likely will not work, due to a fact that it requires HW-based signatures to requests a google signed certificate. This certificate is then validated by all Google Apps.
The download page asks for a access key and / or secret key?
Danton: links are updated.
(08-27-2016, 08:07 AM)ayufan Wrote: Danton: links are updated.
Thanks.
But I see that you removed the links and created a new file for only a 8GB SD card?
Sadly mine is 64GB.
Danton: it doesn't make difference. You can also install it on any other size. I use 64GB for development too.
(08-28-2016, 09:43 AM)ayufan Wrote: Danton: it doesn't make difference. You can also install it on any other size. I use 64GB for development too.
Ah ok! So I don't have to resize the partition?
Thanks for your help, I'm going to flash it immediately!  Cool
Added:
Ok I flashed the SD card and booted it up, but my TV doesn't display everything.
It starts with that I can't see which Wi-Fi network I'm selecting.
Fixed (sort of):
I rebooted the Pine and I think it adjusted itself to display the correct resolution.
Feedback :
4K does not display properly on my Philips PUK7100 TV, only the top half is used.
Yes, there's a problem with DPI after changing resolution. When you see a welcome screen you have to reboot Pine.
Danton: You probably have to reboot after changing resolution. There's also a problem of hardcoded DPI which may not make sense for 4K output. I'll check that on my TV. You can always change DPI with an app like: https://play.google.com/store/apps/detai..._dpi&hl=en
Also a screenshot would be appreciated Smile
Danton: does HDMI CEC work?
For me I get the Android boot screen then what You See in the picture then it reboots and just loops
[Image: IMAG0125.jpg]
#19
Can you connect UART and see what is on the console?
#20
I'll have a go in the morning see whats going on
  Need help compiling android for pine a64 + YeeticusMaximus22 1 417 12-13-2025, 09:23 AM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 538,902 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 43,304 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 27,668 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 10,888 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 12,154 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 8,981 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 5,704 07-15-2019, 08:29 PM
  Issues with SD Card and Running Android Twistedx 0 6,429 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 144,580 02-10-2019, 07:44 PM
Last Post: mmmarcus
Users browsing this thread: 8 Guest(s)
