Android 5.1.1 TV (old-stable, no longer maintained)
The last couple of days I have been working on making our Pine A64 useful, at least in some way. It took some time, but progress is quite promising. Maybe someone would be interested in trying it out.
Features
- I can play Youtube videos and cast them from Phone or Browser,
- I can control Pine using my TV pilot (using HDMI CEC),
- The WiFi appears to not be connecting (but discovering) solved,
- I had troubles with working Bluetooth solved,
- 4K@30fps appears to be working,
- I can run Plex and cast videos using Plex app,
- I can use Android Remote on Mobile,
- I can use Spotify Connect,
- Google Play is not working after first update: this device is not supported, blabla solved,
- Standby over HDMI-CEC doesn't work, when TV sends a standby command and then Power On, Pine will not wake up (disable Auto standby on TV for now).
How to compile?
Tutorial how to compile sources is already written: https://github.com/ayufan-pine64/manifest. Skip only `extract-bsp` part since the kernel is already updated.
How to install?
Download compressed image from:
https://github.com/ayufan-pine64/android-5.1/releases
You can use RasPlex Installer to copy it to card, just point to downloaded image file:
http://www.rasplex.com/get-started/raspl...llers.html
There's a problem with DPI on the first boot. When you see a welcome screen you have to reboot Pine.
Troubleshooting
If someone decides to try this. Please post your `dmesg` log and `adb logcat`. You can connect with `adb` over IP address, like this: `adb connect IP`.
Create an issue here: https://github.com/ayufan-pine64/android-5.1/issues
List of my improvements
- rewrote HDMI CEC kernel driver for our 3.10 and pine64 longsleep sources: https://github.com/ayufan-pine64/linux-3.10 and https://github.com/ayufan-pine64/linux-pine64,
- write HDMI CEC hardware driver for Android: https://github.com/ayufan-pine64/device-...d/hdmi-cec
- configure tulip-chiphd to behave as Android TV: https://github.com/ayufan-pine64/device-..._chiphd.mk
- add 4K output for Android TV (you have to enable Developer options, then Developer Options -> General -> HDMI resolution and choose from 720p, 1080p, 4k@30fps), it even appears to be working on my 4K Dell screen: https://github.com/ayufan-pine64/package...TvSettings
- extend Android TV build: https://github.com/ayufan-pine64/proprie...google_atv
- make the build to behave as fugu to make Google Store to detect this system as only Android TV compatible
- disable IPv6 support to mitigate problems with Allwinner media player which doesn't support IPv6 when playing movies over network
- wrote Power Management module for Android, making this build a 15% faster then original,
- have fully reproducible builds and use CI to build Android images
Nice. It seems to work reliably. It did work OK for over one night now Smile
I didn't try yet,It's a wonderful work!
从我的 iPhone 发送,使用 Tapatalk
I will try it when I get time. One question, if WiFi does not connect, how do you connect? I can't get Ethernet to work under Android or Remix OS.
Thanks for putting this together.
@clarkss12,maybe you can try to use 100m ethernet lan router
I use Ethernet connected to https://wiki.openwrt.org/toh/nexx/wt3020. It works reliably for me, using 1Gbps and 100Mbps. All development I were doing on Ethernet.
It is strange, because WiFi should work too.
Thank You for doing this work. For many of us,  this is why we bought the Pine64.  Sorry the Pine Team did not get a working TV image.
I hope you can get the wifi working soon as well as Playstore.
Can you give us exact install procedures or create an image that we can just put on the SD Card and run.
I don't see why wifi is not working, since everything is there and should be OK.
Right now follow the procedure from above to install it against the current image.
One more thing. I fixed Bluetooth settings to be ON by default. This is required for Android TV.
I also fixed Wifi. It connects and works reliably now Smile
Other change is that default resolution is 1080p, previously 720p.
Playstore seems to be working after tweaking build.prop and configuring:
ro.product.model=fugu
ro.product.brand=Android
ro.product.name=fugu
ro.product.device=fugu
ro.product.board=exdroid
Disabling IPv6 solves a missing video on Google Movies.
  Need help compiling android for pine a64 + YeeticusMaximus22 2 2,348 08-20-2026, 08:45 AM
Last Post: ahegarosib97
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 601,456 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 49,543 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 31,584 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,499 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 13,980 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,413 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,641 07-15-2019, 08:29 PM
  Issues with SD Card and Running Android Twistedx 0 7,391 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 160,675 02-10-2019, 07:44 PM
Last Post: mmmarcus
