LaserCut Pine Enclosure
I made a enclosure for the board
[Image: oTd9Uy3PGVK5.png]
I made some adjustment to stabilize the structure.
So there is the plan (svg and dxf files) : https://github.com/Macrois/Pine64Enclosure
License: CC-by-sa 4.0
Tools:
Laser cutting machine (80w, cut with 80% power and 1000mm/min speed)
MDF 3 millimeter thickness (i guess no problem with acrylic)
Away
That is just straight up beautiful. Very good job.
(05-05-2016, 11:10 AM)Macrois Wrote: Hi,
Tools:
Very nice work and thank you for sharing the files and the info on what equipment you used, now where did my credit card go....
Video
Great design and the .DXF was very easy on my laser cut machine.  I used 3mm black Plexi and glued with plexi solvent.  Great results!
https://app.box.com/s/xx3xkfkwj0cmyeea73t756cxjiv9f030
https://app.box.com/s/m34l74ykjpgg793c1sl3atv19cmx5cpe
https://app.box.com/s/8alph3wyxdgviv7iprx0p9dvvw5a5npk
https://app.box.com/s/ogtojnyix0z794f10s1dduveidibgelo
Tools:
First of all I just want to say thank you for sharing your design with us.
I downloaded and used the .dxf file as a template.
A lot of changes were made.
Kind of pleased with how it turned out.
This is the first real "creation" on my new (and first) lasercutter.
Due to the limits on the attachments I had to make another reply to this topic.
Here is a photo of he hinged lid on the casing....
All these pictures was taken before the case had ben "glued" together.
That case design is positively beautiful !
... thanks for sharing, and again, very nice work.
@Tarjei85: are those antennae?!
How's your WiFi reception? Wink
(08-26-2016, 10:19 AM)Ghost Wrote: @Tarjei85: are those antennae?!
You are correct. Made my own two-way-splitter (the t-splitter was to big) and connected them both...
The wifi reception is awsome Wink
Picked them of an ASUS router I dont use any more Smile
Nicely done Tarjei, and I like the look with the antennas, too! How did you do your own splitter? It appears to be hidden below the WiFi module. Was that pretty simple to do? Thanks.
(08-26-2016, 12:07 PM)montero65 Wrote: Nicely done Tarjei, and I like the look with the antennas, too!  How did you do your own splitter?  It appears to be hidden below the WiFi module.  Was that pretty simple to do?  Thanks.
Thank you. Here is a crappy illustration on how i did it. (When I had it all soldered i covered it in a shrinking-tube to be sure not to mess up anything with any uncovered connections)
Sorry about the crappy illustration. At work right now, and I only had access to MSPaint Tongue
Photo C4 Labs Pine 64 Cases (Standard & LCD) Bluphire 95 239,542 11-02-2020, 08:43 PM
Last Post: Little_Johnny
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 32,547 10-12-2018, 03:08 PM
Lightbulb Perfect ABS Plastic Server Enclosure from Radio Shack MarkHaysHarris777 14 51,354 09-11-2017, 11:39 AM
Last Post: stuartiannaylor
  Clear case PIne 64 with VESA100 LIPO , RTC holder, and mini fan holes killor 6 18,635 08-05-2017, 07:15 AM
Last Post: killor
  New Pine 64 Screen Case from C4Labs Dustin_C4Labs 11 30,099 07-18-2017, 10:39 AM
Information Giving the Pine a trunk, a Playbox pedestal tommypine 7 16,960 07-16-2017, 01:51 AM
Last Post: selina3
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 10,450 06-17-2017, 01:29 AM
Last Post: pfeerick
  Nostalgic enclosure VHS carlo318 4 12,826 03-05-2017, 04:56 PM
Last Post: carlo318
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 9,857 02-12-2017, 10:17 PM
  Enclosure for flush-mounting the 7" touchscreen Learnincurve 9 21,115 02-07-2017, 08:45 PM
Last Post: Bluphire
