MMS sending stopped working
I've been mostly-happily using the PinePhone with Mobian for a long while (years), with MMS working pretty smoothly for a long time. Recently (last 5 days or so), MMS sending has completely stopped working.
  - It didn't happen after making any big software change (apt upgrade, settings change, things like that).
  - Group message sending and 1-on-1 media sending no longer works
  - Group and media receiving still works totally fine
  - Back when MMS sending was working, I noticed that after hitting "send" on an MMS message, the screen brightness would always change for a moment (something to do with power draw to the antenna?). Now when I try to send MMS that doesn't happen.
Any idea what the problem could be?
(01-13-2023, 04:00 PM)amindfv Wrote: I've been mostly-happily using the PinePhone with Mobian for a long while (years), with MMS working pretty smoothly for a long time. Recently (last 5 days or so), MMS sending has completely stopped working.
If it did work before most likely your carrier change something. I am quite sure that because of some carrier changes kop316 need to do some changes (not affecting to me so can't confirm and this comes from my memory so might be wrong).
What you can do is try to upgrade and see what happens?
MMS is complicated and the biggest problem is almost always your carrier (not your own OS or mmsd-tng)
Best place for mms questions is matrix room
#opensourcemms:matrix,org
There was a recent update to mmsd-tng (v2.1.0) to fix a problem that came up with T-Mobile.
It could be a modem or carrier-side issue, especially since you didn’t change anything on your phone. Try rebooting the modem (mmcli -m 0 --reset) or reseating the SIM card; if that doesn’t help, check APN settings for MMS or contact your carrier.
Probably not important but in Mobian the MMS settings has a place for the modem's phone number, what is this all about? I have never seen anything in another mobile running Maemo, android, or v60 having this entry.
(04-29-2025, 05:39 AM)biketool Wrote: Probably not important but in Mobian the MMS settings has a place for the modem's phone number, what is this all about?  I have never seen anything in another mobile running Maemo, android, or v60 having this entry.
It is because otherwise Chatty does not know what is your own phone number (or I am not sure does it know today but that is the reason why the field was added to the settings page)
And why that is important? Because before Chatty might add your number to mms conversations as receiver also - so when you sent message you will also receive it and it did generate huge mess where you might have 6 different "rooms" for one contact because of different mms issues.
Hopefully I explained it good enough xD
You're lucky. I succeeded in sending one MMS some years ago and it has never worked after for me Confused I should contact the developers on matrix.
as for generic info.
i send some mms messages for testing purposes few months ago. this time i didn't test pinephones, but other things.
from my memory. phone number could be blank, it doesn't matter. apn setting works in a cumbersome way. apn need to be set in general mobile data setting, usually it is "mms". of course this disables ordinary internet at that time, hence cumbersome.
  4G VoLTE calls confirmed working with carrier x dcinoz 17 39,939 10-07-2025, 11:05 AM
Last Post: baptx
  My new phone stopped working. gunnygee 3 5,006 12-12-2024, 01:21 PM
  SMS not delivered if receiver offline at sending time alpineduck 14 15,748 09-04-2023, 10:38 PM
  Instructions to get pinephone working on USA carrier omarcomputing 1 4,496 10-08-2022, 04:45 PM
Last Post: treebeard
  stopped receiving text messages jyoung 11 16,616 07-29-2022, 05:36 PM
Last Post: jyoung
  JumpDrive isn't working phytocube 2 5,174 06-05-2022, 03:22 PM
Last Post: phytocube
  SIM card slot not working dekrets 2 5,245 02-12-2022, 11:09 AM
Last Post: dekrets
  Can't get autofocus working duncan_bayne 4 6,877 01-22-2022, 09:17 PM
Last Post: duncan_bayne
  PinePhone Beta 3GB modem not working hannescam 15 20,255 01-19-2022, 02:08 AM
Last Post: bcnaz
  Video Out not working BenniTec 7 11,297 10-21-2021, 11:56 AM
Last Post: BenniTec
