Problem with Wifi, Sleep, Video and PGP signature
Hi everyone!
After 2 years in my drawner, I decided to revive my Pinebook Pro. I wanted to use it to watch Youtube video, Spotify and my Plex media when in the bedroom (don't have any TV there).
So, I downloaded the latest Pinebook Pro image from Manjaro (Manjaro-ARM-kde-plasma-pbpro-23.02) and reinstalled the whole laptop.
Saddly, I found out that this version has some problems that previous one didn't had :
- When put to sleep, the computer don't come back on. Must force poweroff
- Wifi stop working on reboot. Needs poweroff/poweron
- Videos are sluggish on Youtube
So, I decided to try a previous ISO I had (Manjaro-ARM-kde-plasma-pbpro-21.12) and I have none of theses problem with the Pineboook Pro!
But I have, then, another problem : completly unable to update anything! I always get PGP error. I tried to :
pacman-mirrors -f5
pacman -Syy manjaro-keyring archlinux-keyring
None of them fiex my PGP problem.
So ...
how can I use the old version and update it correctly OR how can I use the new one and get by the old stability (sleep, wifi, video accelaration) ?
My understanting of Linux is not good enough for me here.
Thanks in advance for you help!
Have you tried this?
https://forum.manjaro.org/t/howto-solve-...jaro/96949
When I ran into that it didn't work as expected the first time but eventually I got it to work. Sadly I didn't bother to document what I did.
In the meanwhile you can make sure the CPU clocks are running fast enough. I recently set mine up to watch March Madness and found out that at 1416MHz on all 6 processors it works adequately. 1416 on four and 1800 on the other two and it's very good. And that's without the video acceleration that you should have with Manjaru.
:wq
(03-30-2025, 01:49 PM)KC9UDX Wrote: Have you tried this?
Ok. I will test.
For the CPU speed, how do I check/adjust that?
Thanks!
(03-30-2025, 03:00 PM)Anarethos Wrote: For the CPU speed, how do I check/adjust that?
I'm not much of a linux user (my wife is though she might not even know it Smile ) but in NetBSD, which I use:
sysctl -a | grep freq
sysctl -w machdep.cpufreq.cpu4.target=1800
sysctl -w machdep.cpufreq.cpu0.target=1416
BTW, this is going to reduce your battery life (maybe a lot) and depending on ambient conditions (and whether you're charging) possibly make your PBP overheat.
:wq
Thanks!
Finally I gave up on making pacmac works on the 21.12 image. I found that I also had the 22.04 image which was OK (wifi, speed, sleep mode) and pacmac works with that one so I am good to go right now.
  Charging problem RicTor 1 735 05-21-2026, 02:27 AM
Last Post: Rodery
  Pinebook problem meghancordo 2 5,542 03-18-2026, 08:58 AM
Last Post: RicTor
  Problem: Wi-Fi Connectivity Issues on Pinebook Pro markwood00 1 5,662 02-05-2025, 03:56 AM
Last Post: waylonwesley
  Video Flashing/adjusting on boot and reboot jbradley419 0 2,522 01-16-2024, 09:17 AM
Last Post: jbradley419
  Video Editing Is Possible On The PineBook Pro! ImmyChan 9 15,890 12-17-2023, 09:29 PM
Last Post: insideau786
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 2,704 07-13-2023, 01:50 PM
Last Post: PaulQ
  U-Boot, video console, and visual artifacts dsimic 21 35,016 03-16-2023, 07:30 AM
Last Post: Tazdevl
  wifi missing some networks filip 0 1,932 03-11-2023, 03:21 PM
Last Post: filip
  invalid or corrupted package (PGP signature) Mangustis 0 2,706 02-21-2023, 04:50 PM
Last Post: Mangustis
  eMMC problem with Tow-Boot/u-boot on SPI repa 3 5,046 02-21-2023, 01:49 AM
Last Post: repa
