invalid or corrupted package (PGP signature)
Hi everyone!
Today I reinstalled my PB Pro with last Manjaro distro. When a started process of installation of all my soft at previous instance I faced a problem with transaction commit. After any soft installation attempt I have error "nvalid or corrupted package (PGP signature)" (even pacman in terminal). I found some advises about refreshing keys, but still haven't solution. Please help to solve it.
Installation example:
$ sudo pacman -S remmina resolving dependencies... looking for conflicting packages... Packages (6) ayatana-ido-0.9.2-1  libayatana-appindicator-0.5.92-1  libayatana-indicator-0.9.3-1              vte-common-0.70.3-1  vte3-0.70.3-1  remmina-1:1.4.29-1 Total Installed Size:  6,58 MiB :: Proceed with installation? [Y/n] y (6/6) checking keys in keyring                                     [####################################] 100% (6/6) checking package integrity                                   [####################################] 100% error: vte-common: signature from "Arch Linux ARM Build System <builder@archlinuxarm.org>" is unknown trust :: File /var/cache/pacman/pkg/vte-common-0.70.3-1-aarch64.pkg.tar.xz is corrupted (invalid or corrupted package (PGP signature)). Do you want to delete it? [Y/n] n error: vte3: signature from "Arch Linux ARM Build System <builder@archlinuxarm.org>" is unknown trust :: File /var/cache/pacman/pkg/vte3-0.70.3-1-aarch64.pkg.tar.xz is corrupted (invalid or corrupted package (PGP signature)). Do you want to delete it? [Y/n] n error: ayatana-ido: signature from "Arch Linux ARM Build System <builder@archlinuxarm.org>" is unknown trust :: File /var/cache/pacman/pkg/ayatana-ido-0.9.2-1-aarch64.pkg.tar.xz is corrupted (invalid or corrupted package (PGP signature)). Do you want to delete it? [Y/n] n error: libayatana-indicator: signature from "Arch Linux ARM Build System <builder@archlinuxarm.org>" is unknown trust :: File /var/cache/pacman/pkg/libayatana-indicator-0.9.3-1-aarch64.pkg.tar.xz is corrupted (invalid or corrupted package (PGP signature)). Do you want to delete it? [Y/n] n error: libayatana-appindicator: signature from "Arch Linux ARM Build System <builder@archlinuxarm.org>" is unknown trust :: File /var/cache/pacman/pkg/libayatana-appindicator-0.5.92-1-aarch64.pkg.tar.xz is corrupted (invalid or corrupted package (PGP signature)). Do you want to delete it? [Y/n] n error: remmina: signature from "Arch Linux ARM Build System <builder@archlinuxarm.org>" is unknown trust :: File /var/cache/pacman/pkg/remmina-1:1.4.29-1-aarch64.pkg.tar.xz is corrupted (invalid or corrupted package (PGP signature)). Do you want to delete it? [Y/n] n error: failed to commit transaction (invalid or corrupted package (PGP signature)) Errors occurred, no packages were upgraded.
"Yes" as answer for deleting brings same result.
Command "sudo pacman-keys --refresh-keys" can't complete fully and hangs after 10 seconds:
$ sudo pacman-key --refresh-keys gpg: error retrieving 'philm@manjaro.org' via WKD: No data gpg: error reading key: No data gpg: refreshing 1 key from hkps://keyserver.ubuntu.com gpg: key CAA6A59611C7F07E: 4 signatures not checked due to missing keys gpg: key CAA6A59611C7F07E: "Philip Müller (Called Little) <philm@manjaro.org>" not changed gpg: Total number processed: 1 gpg:              unchanged: 1 gpg: error retrieving 'lennart@poettering.net' via WKD: General error gpg: error reading key: General error gpg: error retrieving 'lennart@poettering.de' via WKD: General error gpg: error reading key: General error gpg: error retrieving 'lpoetter@redhat.com' via WKD: No data gpg: error reading key: No data gpg: error retrieving 'poettering@users.sourceforge.net' via WKD: No data gpg: error reading key: No data gpg: refreshing 1 key from hkps://keyserver.ubuntu.com gpg: key 327F26951A015CC4: 1 duplicate signature removed gpg: key 327F26951A015CC4: "Lennart Poettering <lennart@poettering.net>" not changed gpg: Total number processed: 1 gpg:              unchanged: 1 gpg: error retrieving 'jr@jriddell.org' via WKD: No data gpg: error reading key: No data gpg: refreshing 1 key from hkps://keyserver.ubuntu.com gpg: key EC94D18F7F05997E: "Jonathan Riddell <jr@jriddell.org>" not changed gpg: Total number processed: 1 gpg:              unchanged: 1 gpg: error retrieving 'klember@redhat.com' via WKD: No data gpg: error reading key: No data gpg: error retrieving 'kalevlember@gmail.com' via WKD: No data gpg: error reading key: No data gpg: refreshing 1 key from hkps://keyserver.ubuntu.com gpg: key 80858FA38F62AF74: "Kalev Lember <klember@redhat.com>" not changed gpg: Total number processed: 1 gpg:              unchanged: 1 gpg: WARNING: unacceptable HTTP redirect from server was cleaned up gpg: no valid OpenPGP data found. gpg: Total number processed: 0 gpg: error retrieving 'jasuarez@igalia.com' via WKD: No fingerprint gpg: WARNING: unacceptable HTTP redirect from server was cleaned up gpg: no valid OpenPGP data found. gpg: Total number processed: 0 gpg: error retrieving 'jasuarez@igalia.com' via WKD: No fingerprint gpg: refreshing 1 key from hkps://keyserver.ubuntu.com gpg: key 336909B6B25FADFA: "Juan A. Suarez <jasuarez@igalia.com>" not changed gpg: Total number processed: 1 gpg:              unchanged: 1 gpg: error retrieving 'emil.l.velikov@gmail.com' via WKD: No data gpg: error reading key: No data gpg: refreshing 1 key from hkps://keyserver.ubuntu.com gpg: key EDAE37B02CEB490D: "Emil Velikov <emil.l.velikov@gmail.com>" not changed gpg: Total number processed: 1 gpg:              unchanged: 1
  Problem with Wifi, Sleep, Video and PGP signature Anarethos 4 6,870 03-31-2025, 07:14 AM
Last Post: Anarethos
  Metis package can't update Mangustis 1 4,076 02-22-2023, 03:23 PM
Last Post: robocone
Big Grin Selling Pinbook Pro AND pinephone convergence package poltergiest 2 5,406 03-08-2022, 10:12 AM
Last Post: poltergiest
  L2TP Client Package For PBP CloudPlumber42 10 18,643 02-07-2020, 03:23 AM
Last Post: evilbunny
  PBP ARM Processor RECOGNIZED by Default Debian OS Synaptic Package Manager jcj52436999 14 30,653 12-19-2019, 11:28 AM
Last Post: User 6582
