Not able to power on PineTab anymore
Hi, hoping that maybe someone has advice on this...
After finally getting my pinetab connected to wifi, I ran
sudo pacman -Syu
for the first time, and suddenly during the update I got a big message
This screen locker is broken and unlocking it is not possible...
and from there on, the pinetab did not react to anything anymore...
I tried to restart it, but after it had successfully been powered off, I've not been able to power it on anymore... It just stays dark.
I've also tried connecting to the laptop via the UART console, to see if it's just the display - but I don't see anything in a screen terminal either.
I have no idea what to do, since I can't re-install without somehow switching it on...
Would anyone have an idea what to do? Many thanks!!
Given it failed on an update I suspect that it is not a hardware issue, just something that was borked in the update.
There are a couple things we can check.
What software did you use on the laptop for the UART adaptor? What message did you get when you tried?
Otherwise did you ever change anything with the bootloader of the system? If not it should be possible to simply boot to an SD card with no additional changes.
Do you have access to a microSD card? Perhaps try getting a copy of, say mobian, https://images.mobian.org/pinetab2/weekly/ on an SD card and try to boot that up.
For getting mobian on the SD card, I recommend using bmaptool to copy it, it was significantly faster than using dd.
Hi, many thanks for your response!!
I did sudo screen /dev/ttyUSB0 1500000, as per the pinetab wiki (https://wiki.pine64.org/wiki/PineTab2#Co...RT_adapter). I didn't get any message, just a blank screen (which stayed blank after trying to power on the pinetab).
Oh, that's great to know. I didn't change the bootloader. I will do as you say, and let you know ASAP!
Thanks again!
Perhaps try the UART adaptor with minicom instead of screen as well.
I was able to reproduce what you described with my pinetab. On screen I tried a couple of times and had no message the first time, and only an illegible message the second time, but with minicom I get the correct output that shows the bootup process. This is with a pinetab that likely has a similar issue to yours as the original install is not working and I am running from the SD card slot.
So hopefully this is what you need to fix it.
For me, I am using this as an opportunity to try out different images from the SD card before reinstalling.
Good luck
(12-25-2023, 02:31 PM)zkajdan Wrote: Hi, hoping that maybe someone has advice on this...
sudo pacman -Syu
Hi. I've run into this very exact problem just yesterday.
I think it's the end of it. Pity I rarely use it.
  Unknown Startup Password for Newly Delivered PINETAB-V - 10.1" 8GB/128GB krupine2 1 498 10-05-2026, 12:44 PM
Question Will Pinetab 2 spare parts be available? vatin 6 9,130 12-09-2023, 01:31 AM
  ?brighter screen replacement for pinetab (>1600 nits) dynobang 0 3,490 09-28-2023, 01:06 PM
Last Post: dynobang
  [Tutorial] How to overclock Pinetab 2 Darth-Apple 0 4,563 09-25-2023, 08:45 AM
Last Post: Darth-Apple
  External Reset button on PineTab V? michaelengel 0 3,110 09-18-2023, 06:31 AM
Last Post: michaelengel
  Pinetab 2 screen no longer coming on Fibonacci 9 13,804 06-30-2023, 08:26 AM
Last Post: Purple_Illusion
  Pinetab completely bricked Saksmito 8 10,783 06-10-2023, 04:23 PM
Last Post: fxc
  What RISC-V chip will the PineTab-V use? msm 2 5,039 04-05-2023, 06:58 PM
Last Post: msm
Big Grin Howto: Pinetab Screen Replacements (+ Pictures) RTP 5 13,129 02-10-2022, 08:31 PM
Last Post: barray
  Offer: PineTab with keyboard firefox-58 3 8,376 09-27-2021, 12:36 PM
Last Post: stmguard
