Pine64 Boot help needed
Hi Guys,
quick question surrounding the writing Remix OS to the SD card. I have successfully completed both using Win32 and phoenix card but my Pine 64 has yet to boot past the Pine64 opening screen. I just wondered how I could check the image has successfully been written to the SD card... I've ordered a power cable with the correct amps but just wanted to make sure I am actually writing the image correctly.
Thanks,
Check your power supply. usual cellphone chargers have 5V 1A. What works for me is 5V 2.4A (They said 5V 2A works, I had 5V 2.1A and it didn't go past RemixOs. )
(06-15-2016, 02:18 AM)racann Wrote: Check your power supply. usual cellphone chargers have 5V 1A. What works for me is 5V 2.4A (They said 5V 2A works, I had 5V 2.1A and it didn't go past RemixOs. )
Thanks, racann. I've just ordered my second power supply from Amazon but it's 5V 2A... I'll give that a try but might have to buy a higher powered one by the sounds of it. Don't know what else it could be.
Here is what the image looks like on a 16GB card as viewed in MiniTool Partition Wizard.  If you burnt it to a 16GB card, everything below is exactly the same except E:(Ext3) would have a total capacity of 27.22 GB ....the reat of the partitions are exactly the same regardless of chip size.  Also whether I used Win32 or PhoenixCard to burn, both images looked the same....hope that helps.
[img]<a href=[/img][Image: 06.15.2016-09.46.png] " />
I rely on a Raspberry Pi 2 power supply which is rated for 5V/2A and it works fine.  A high quality PS with similar specs should work.  A more powerful 2.4A should work equally as well.
  Star64: All listed distros don't boot tantamount 0 465 05-08-2026, 08:56 AM
Last Post: tantamount
  Having trouble reading MPU6050 sensor via I²C on Pine64 Jaxon 3 9,533 10-21-2025, 10:13 AM
Sad PINETAB-V doesn't boot. FEC 1 3,126 08-23-2025, 02:58 PM
Last Post: Woazboat
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 3 5,952 12-10-2024, 07:23 PM
Last Post: Dendrocalamus64
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 2,961 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 3,528 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 4,395 05-24-2023, 02:45 AM
Last Post: draintroup
Exclamation Quartz64 model a wont boot AndyNZAUS 0 3,148 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 3,422 08-24-2021, 08:17 AM
Last Post: lamson
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 6,460 06-17-2021, 05:35 AM
Last Post: kqlnut
