Having trouble reading MPU6050 sensor via I²C on Pine64
Hello everyone,
I’m trying to read data from the MPU6050 6-axis sensor via I²C on my Pine64 board, but I’m running into some issues.
System: Armbian
I²C is already enabled, and I can see the device address 0x68 with i2cdetect -y 1
My Python script runs, but the data I get is unstable and often jumps around
Has anyone successfully driven the MPU6050 on Pine64? Do I need any additional configuration?
Thanks!
I had the same problem when working with the MPU6050 on a Pine64 board, and a few things made the difference:
Use 3.3 V instead of 5 V to avoid level shifting issues.
On initialization, write to register 0x6B (as described in the MPU6050 datasheet) to wake the device from sleep mode.
To smooth out the jitter, apply a simple moving average or even a Kalman filter depending on your needs.
Once I followed the datasheet’s register setup and wiring, the readings became much more stable.
Make sure you're using a reliable library like smbus2 or Adafruit_CircuitPython_MPU6050.
Here's a simple example using smbus2:
import smbus2
import time
bus = smbus2.SMBus(1)
address = 0x68
# Wake up MPU6050
bus.write_byte_data(address, 0x6B, 0)
def read_word(adr):
    high = bus.read_byte_data(address, adr)
    low = bus.read_byte_data(address, adr+1)
    val = (high << 8) + low
    return val
def read_word_2c(adr):
    val = read_word(adr)
    if (val >= 0x8000):
        return -((65535 - val) + 1)
    else:
        return val
while True:
    accel_x = read_word_2c(0x3B)
    print("Accel X: ", accel_x)
    time.sleep(0.5)
If you or anyone reading this have the skills a joystick driver for the gyros would make playing games and emulator much better than using an external device.
  reading the inserted SSD gilwood 1 3,913 01-01-2022, 12:11 AM
Last Post: ryo
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 3,681 08-24-2021, 08:17 AM
Last Post: lamson
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 6,966 06-17-2021, 05:35 AM
Last Post: kqlnut
  Just discovered Pine64 ! - first Q philip_rhoades 4 10,061 04-29-2020, 10:13 AM
  A newest user in Pine64 Aliko 1 6,512 04-19-2020, 10:33 PM
  PINE64 Installer - Simple Way to Image Your MicroSD pineadmin 101 213,153 01-15-2020, 12:46 PM
  Emails from pine64 received as spam by gmail Matan 2 14,659 08-21-2019, 08:30 AM
Last Post: Leiaz
  How to handle a Pine64 correctly gbjensen 6 22,805 03-28-2019, 11:43 PM
Last Post: InsideJob
Information Creating a NAS server in Pine64 javi_cala 4 12,308 01-21-2019, 02:03 AM
Last Post: bartes
  The 6 most common reasons why Pine64 won't boot Andrew2 109 302,927 10-11-2018, 11:35 PM
Last Post: Technolab88
