Another one boots to black screen
I got my pine book pro back in march, put towboot on the spi and ran armbian from the emmc. Happy! After a period of disuse including full battery discharge, it started booting to a black screen. Sad!
I put a new image of armbian on an SD card and it does the same thing. I opened the case and turned off the emmc switch and tried a fresh SD card. No change. I tried the long press hard reset. Same.
Tow boot is still working. When it boots to the black screen, the power light is green and the caps lock and num lock lights work.
I’m not sure what to do next.
Well, you could zero the SPI ROM, have the eMMC disabled, and boot to the SD card, assuming the SD card actually boots.
:wq
[ SRA accepts you ]
Everyone wants me to quit using NetBSD
Towboot on the spi is the only thing that is working correctly. It does not boot to the SD card.
I think I’m going to replace the main board and emmc. Maybe a power surge from fully discharging the battery fried something.
I could not find another case like mine where the boatload works and nothing else does.
banana game
It looks like your Pinebook Pro is having trouble booting, even though Tow-Boot still works. Try these steps: check the display on an external display via USB-C or HDMI to see if there is a signal; use an older version of Armbian or another operating system such as Manjaro; reset SPI flash by reinstalling Tow-Boot; Collect boot logs via UART port to view detailed errors; and try removing the battery, holding down the power button to discharge before reinserting. If the above steps fail, collecting the boot log can help determine the exact cause.
best regard,
With a black screen I'm not sure how you could manage to zero SPI
Armbian AFAIK starts a ssh session, so if you can find the IP address.....
OR if that doesn't work (no wifi connect) plug a usb-ethernet dongle and ethernet in
I was able to get it to boot with a usb drive with the original version of armbian that was previously working. Version 24.2.1, current 6.6.16, gnome desktop.
I will attempt the Sd card with this image and also will attempt to install on the emmc again.
Works with the sd card too. Appears the most current version of armbian is broken compared to this version.
Back booting from emmc. Happy. My issue was caused by a bad image of armbian. Thank you to the very chatgtp type response telling me to try other versions.
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 689 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Black screen by start up bluedemon382 10 4,410 07-27-2023, 07:49 AM
Last Post: dstallmo
  PBP blank screen after updating Manjaro Franko 6 2,985 04-01-2023, 07:55 AM
Last Post: hacknix
Question Pinebook Pro shows only bright white screen when powered on Sean Whitton 3 2,575 07-22-2022, 01:19 PM
  Ring around screen following update tylerjohnson3208 2 2,575 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Looking for Screen LCD Panel for the Pinebook Pro gerstavros 3 3,369 05-09-2022, 05:53 AM
Last Post: gerstavros
  Putting my screen on TV S265 6 5,646 10-07-2021, 08:00 PM
Last Post: ajawadmahmoud
  My pbp is a sleek, black, flat brick, and won't boot from any kind of media rotwang 15 16,497 08-24-2021, 04:25 PM
Last Post: bkenn
  Flickering black window when opening settings Edgars10 0 1,570 06-06-2021, 05:42 AM
Last Post: Edgars10
  Screen refresh delay with kernel errors shawnanastasio 31 43,836 04-27-2021, 02:57 AM
Last Post: james64
