Manjaro 20.04 not loading from SD (with Manjaro on eMMC)
I have Manjaro installed on the eMMC.  I used the Manjaro-ARM-xfce-pbpro-20.04-emmc-installer-20.04.img from OSDN, and then updated it.
Since then I've been able to try various operating systems on SD (eg. Ubuntu, Debian), but I can't seem to run Manjaro-ARM-xfce-pbpro-20.04.img from SD.
It's not simply that they are both Manjaro.  Manjaro-ARM-gnome-pbpro-23.02.img on SD loads.
Is there a way I can get Manjaro-ARM-xfce-pbpro-20.04.img to load without opening the computer and physically switching off the eMMC?
When I try to run Manjaro-ARM-xfce-pbpro-20.04.img off SD, the computer runs Manjaro off the eMMC and the SD shows as an external drive.
The reasons I want to run Manjaro-ARM-xfce-pbpro-20.04.img from SD is so I can update and configure it so I have back up in case the eMMC fails, and also have system where I can try things without breaking the OS on eMMC.
(Using Manjaro-ARM-xfce-pbpro-23.02.img from Manjaro's site instead wouldn't work because HDMI via USB-C only seems to work with the OSDN images.)
Any ideas?
Try .... sudo blkid ,, is the fs labels duplicated? Also cat /etc/fstab
IIRR manjaro uses fslabels in fstab
So, change labels on sd, add "-sd" suffix, edit fstab and maybe extlinux.conf
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,491 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,125 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,251 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 4,054 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,562 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 3,918 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,172 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,374 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 5,270 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 4,834 08-21-2023, 09:10 PM
Last Post: vanessadonald
