Kali Linux for Pinebook Pro - stuck on the login screen
Hi everyone,
I want to be able to run kali off of the pinebook pro as needed via the SD card. I followed the Pinebook Pro installation instructions here: https://www.kali.org/docs/arm/pinebook/
* Download and validate the kali linux image
* flash the kali-linux-2023.2-pinebook-pro-arm64.img file to the SD card (note, no errors or issues took place on flashing the SD card)
* insert the SD card to the pinebook pro
* start the machine
From here, I'll see what appears to be the boot process loading which is a wall of text. Note that I saw several "FAILED" "Failed to start ssh.service - OpenBSD SecureShell error, etc.
kali-pinebook-pro login:
password:
After the booting process stops, I am dropped into a CLI login screen. I attempt to use the kali login defaults e.g. username: kali and password kali which shows as invalid. Does anyone have the default login and password or can we determine if I did something horribly wrong?
Thank you!
  Boot Order in Pinebook Pro food 12 18,717 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 6,358 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,146 08-09-2025, 06:53 AM
Last Post: Sb2024
  Can’t login to Linux fnosai 0 3,320 07-27-2025, 12:30 AM
Last Post: fnosai
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,356 02-19-2025, 12:49 PM
Last Post: zkajdan
  Void Linux: missing firmware from pinebookpro-firmware? remph 0 3,366 12-15-2024, 01:58 PM
Last Post: remph
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 6,885 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,514 08-21-2024, 04:17 AM
  Slackware Linux working on PBP vxzero 0 4,030 06-05-2024, 04:30 PM
Last Post: vxzero
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,691 05-31-2024, 09:42 AM
Last Post: SynthGal
