openHAB Packaging for the Pine64
(06-08-2016, 10:56 PM)scurrier Wrote: ...
Reason I ask is that I jumped the gun and two days ago spent some hours getting openhab running on the most recent longsleep kernel in a non-headless config.  I'd like to just update the docker image to your most recent one instead of moving to the headless system.
Also, wondering if you have any guesses how far away zwave compatibility is.  Thanks!  Big openhab fan!
You may join our discussion here.
I was supposed to get a SD card with OpenHAB pre-installed, but got an Android release instead. I'm comfortable with installing a base OS, then Docker and then using an OpenHAB container. I just want to make sure I get the right base image, since my current network layout is wireless - so I can't really use a headless image. Do I just grab the Debian image in the downloads section, and then add Docker? I have an Ubuntu (Mate GUI) - can I use that or are the libraries too different?
Or should I just request the pre-installed OpenHAB SD?
(07-31-2016, 12:15 AM)ewickham Wrote: I was supposed to get a SD card with OpenHAB pre-installed, but got an Android release instead. I'm comfortable with installing a base OS, then Docker and then using an OpenHAB container. I just want to make sure I get the right base image, since my current network layout is wireless - so I can't really use a headless image. Do I just grab the Debian image in the downloads section, and then add Docker? I have an Ubuntu (Mate GUI) - can I use that or are the libraries too different?
Sorry on teh shipping facility ship you the SD card with Android release. For OpenHAB build, you can download from http://wiki.pine64.org/index.php/Pine_A6...AB_Release and dd to the microSD card.
I'm still a little uncertain about what to expect once I download the image to the SD card and reboot the Pine64. Will I see a console login via HDMI? Maybe on an LCD display via the DSI connector? As I mentioned previously, my current work area for the Pine64 forces me to use wireless - and since mine is secured, I have to provide  authentication at some point. Will I need to use a wired ethernet connection first in order to configure the wireless? I presume once connectivity is configured I can ssh to the server, yes?
The openHAB build works as headless.
(08-01-2016, 01:47 PM)tllim Wrote: Sorry on teh shipping facility ship you the SD card with Android release. For OpenHAB build, you can download from http://wiki.pine64.org/index.php/Pine_A6...AB_Release and dd to the microSD card.
I saw that Kai tweeted that he had success with Z-wave. I want to try the latest image but when I go to the link I am directed to an image for pine64_openhab_20150521_8GB.zip. Is that really from May 21st, 2015 or is it the latest?
There is no 20150521 build, the release one is 20160415 build. My guess that he tested on this build.
(08-06-2016, 01:20 PM)B34N Wrote: I saw that Kai tweeted that he had success with Z-wave. I want to try the latest image but when I go to the link I am directed to an image for pine64_openhab_20150521_8GB.zip. Is that really from May 21st, 2015 or is it the latest?
I also tweeted "the next SD card image will support it", which doesn't mean the "current" supports it! I plan to provide the next one for beta4 somewhen by the end of September.
The new openHAB beta 4 already upload to Pine64 wiki site, this one supports ZWave.
@kai
You should mention openHABian's support for the Pine A64 in the first posting here.
http://docs.openhab.org/installation/ope...l#pine-a64
  openHABian for pine64 available dmcwhinnie 5 17,798 12-20-2017, 10:38 PM
Last Post: pineadmin
  Pine A64 + OpenHAB + Sonoff-pow: Would it Work? Bob123456789 6 17,285 05-31-2017, 02:54 PM
Last Post: Bob123456789
  Show Hubpanel on pine64 display Beta 0 5,010 04-15-2017, 05:44 AM
Last Post: Beta
Tongue Pine64 with Openhab2 - Starting guide/accessories g_t_j 4 15,037 03-12-2017, 05:13 PM
Last Post: BatoXan
  Keeping Openhab current socken23 4 13,045 01-13-2017, 12:51 AM
Last Post: swinging
  Pine64 and Aeon labsZ-Stick tomekr 1 7,521 12-19-2016, 05:41 PM
Last Post: Trond
  Pine64 and MQTT Grootkonijntje 2 12,059 09-22-2016, 04:01 AM
Last Post: pfeerick
  OpenHAB And Zwave FrenchFrog 12 34,588 09-13-2016, 11:17 PM
Last Post: bonterra
  OpenHAB Up - Getting My Bearings - Questions doundounba 4 12,402 07-08-2016, 12:38 AM
Last Post: av1024
Information [solved] Openhab not starting socken23 10 25,288 06-21-2016, 12:50 PM
Last Post: Luke
