Pine64 and MQTT
Are there any options for integrating Mosquitto support on the Pine ?
Which Linux distributions will work with it ?
I'm a newbie at Linux, so have a little patience with me please
(09-22-2016, 03:15 AM)Grootkonijntje Wrote: Are there any options for integrating Mosquitto support on the Pine ?
apt-get update && apt-get install mosquitto should do the trick, or equivalent for non-debian based distros.
(09-22-2016, 03:26 AM)j.hoekstra Wrote: apt-get update && apt-get install mosquitto should do the trick, or equivalent for non-debian based distros.
I can confirm. Have been running mosquitto on my pine64's debian image pretty much since I got the board. You can also run apt-get install mosquitto-clients to get the mosquitto_sub command for testing your mosquitto install.
  openHABian for pine64 available dmcwhinnie 5 17,798 12-20-2017, 10:38 PM
Last Post: pineadmin
  Show Hubpanel on pine64 display Beta 0 5,010 04-15-2017, 05:44 AM
Last Post: Beta
Tongue Pine64 with Openhab2 - Starting guide/accessories g_t_j 4 15,034 03-12-2017, 05:13 PM
Last Post: BatoXan
  openHAB Packaging for the Pine64 kai 19 51,111 02-21-2017, 07:19 AM
Last Post: BatoXan
  Pine64 and Aeon labsZ-Stick tomekr 1 7,518 12-19-2016, 05:41 PM
Last Post: Trond
  openHAB just up on Pine64 :-) tllim 2 11,375 05-04-2016, 05:27 AM
Last Post: Luke
  openHab2 on pine64 tomekr 15 41,076 04-19-2016, 01:14 AM
Last Post: umiddelb
