New Pinebook pro won’t boot
I’ve searched the forums but haven’t found any answers to my problem I received my PBP yesterday before work I decided to setup the laptop and update it everything was going smooth and I was generally happy with my purchase I started the update command it said something about outdated keys I updated those continued with the update and rebooted the device (all through the terminal) after that it hung on the restart screen for a moment then restarted it flashed the boot up screen for Manjaro with the loading symbol and then went blank after about 5 or so minutes I held the power button to force the device off and now I get a blank screen with everything EMMC/microsd/ and usb won’t even work my usb drive receives no power no matter the usb port I use (mine has a power indicator so I can tell if it’s in use or not) so I’m stuck I have no idea what to do the power light on PBP is solid green just no activity on the screen whatsoever do I need to disable my EMMC or mess with the SPI? Any help is appreciated thank you!
I'm slightly surprised you couldn't find anything because this is terribly common.
You'll have to create a bootable SD card with the operating system of your choosing.   Then, disable your eMMC, boot to the SD card, re-enable the eMMC, wipe it, and install new OS.
Recommend opening the PBP 90° and hang the display over the end of a table to do the eMMC disable/re-enable process.  Either assemble the bottom, or only pick up the PBP by the display half when it's disassembled.  Handling it by the keyboard half with the bottom cover removed will surely cause damage.
:wq
(03-25-2023, 12:04 PM)KC9UDX Wrote: I'm slightly surprised you couldn't find anything because this is terribly common.
thank you for the prompt reply i was able to get the PBP to work again but just repeating the steps with different sd cards using different flashers what ended up working was when i used my raspberrypi 4 and flashed manjaro using raspberry pi imager now im running off the emmc after using the manjaro flashing tool.
Quote:I'm slightly surprised you couldn't find anything because this is terribly common.
I've made a huge mistake.
Well, it's not you, it's Manjaru, unfortunately.  But since @Generaltuxenburg was able to recover without opening the PBP, you should be able to, too, hopefully.
:wq
  Updated Pinebook Pro? tantamount 2 2,446 06-20-2026, 10:14 AM
Last Post: tantamount
  Pinebook pro bricked? michaelmoua 4 8,248 05-26-2026, 02:20 AM
Last Post: Anthona
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 1,863 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 3,522 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 6,947 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 10,880 02-09-2026, 12:50 AM
Last Post: Anthona
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 2,215 12-18-2025, 01:05 AM
Last Post: qingss0
  Pinebook Pro for sale rfm83 0 2,043 11-08-2025, 09:22 AM
Last Post: rfm83
  Bonk to boot biketool 2 2,795 10-21-2025, 09:08 AM
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 8,922 08-02-2025, 08:55 PM
