Manjaro update: nerd-font-terminus dependency issue
Hi there,
when updating Manjaro on my Pinebook Pro (pressing that red shield with the exclamation mark in the Plasma taskbar) the update crashes with the following remark:
Quote:could not satisfy dependencies:
- removing nerd-fonts-terminus breaks dependency 'nerd-fonts-terminus' required by manjaro-arm-i3-settings
So it has not updated for a while. Does anyone have an idea how to solve this? Of course if you feel this question has already been answered, feel free to point me to the correct thread. I did a search but couldn't find anything about this particular issue, only that ttf-terminus-nerd does conflict with this package. But the update doesn't seem to include ttf-terminus-nerd so I can't uncheck that one for the update.
Thanks!
My son's pbp got into a circular dependency loop,
got out using pamac command line program for update
Thanks a lot for taking the time to respond. I just tried your suggestion, but it doesn't seem to work in this case.  This is what I got:
[vinay@dennenappel openvpn]$ pamac update
Preparing...
Synchronizing package databases...
Resolving dependencies...
Checking inter-conflicts...
Error: Failed to prepare transaction:
Hi all, a small update. I posted the issue on the Manjaro forum and got very quick and accurate help. They did indeed have to perform a small update on April 27th which solved it for me.
For the updates I now use the command
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syu
You can read the discussion here: https://forum.manjaro.org/t/pbp-update-i...s/139433/3
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 3,390 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 4,990 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 5,690 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 3,622 03-08-2024, 08:41 AM
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 3,513 03-01-2024, 06:46 PM
Last Post: Puckla
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,062 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 3,249 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 8,885 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 10,349 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,011 12-07-2023, 03:11 PM
