tow-boot installation problem
I am working on getting tow-boot to work on my PPP. I can get it installed, but when I boot it up afterwards it will turn the red LED on, and do the vibes thing, then turn yellow and four vibes, it waits a bit before flashing and vibrating like 10 times, then it seems to turn off. Holding down the up volume it acts similarly but turns the light blue first, before turning red and blinking.vibing a few times, pausing, then doing the ten vibe blink thing and turning off. If its on a charger, it just keeps looping that. If it's attached to a computer it never gets recognized, just loops like on a charger. I have gone through the tow-boot several times, watched videos, paid very close attention to detail and it does it every time. I erased the SPI before installing, and same thing.
I just got the phone this weekend if that helps any. It was running ok with the default manjaro plasma, I did run manjaro phosh off an SD and attempted to install it to emmc, it took forever and I thought it failed/stalled but eventually it said it completed it. It would not boot off it though. In the meantime I was researching stuff and came across tow-boot as the thing to do to make swapping OSes easier so I went for it and here we are.
Any ideas would be great. Thanks.
(02-15-2023, 03:02 PM)techariah Wrote: I am working on getting tow-boot to work on my PPP. I can get it installed, but when I boot it up afterwards it will turn the red LED on, and do the vibes thing, then turn yellow and four vibes, it waits a bit before flashing and vibrating like 10 times, then it seems to turn off. Holding down the up volume it acts similarly but turns the light blue first, before turning red and blinking.vibing a few times, pausing, then doing the ten vibe blink thing and turning off. If its on a charger, it just keeps looping that. If it's attached to a computer it never gets recognized, just loops like on a charger. I have gone through the tow-boot several times, watched videos, paid very close attention to detail and it does it every time. I erased the SPI before installing, and same thing.
additional info/update. I flashed the postmarket installer to an SD card, booted off that, did the install and everything looked fine. Removed the Sd card and in it's behaving the same as above. Maybe I misunderstood "installer?" Just tried to boot back off the SD and it seems to work there, so I guess I did misunderstand that. Also of note, when I hold volume down on boot, it does turn the LED teal like tow-boot says.
Well, after continued research I finally found a post that addressed the issue. Evidently that first move to flash the emmc that failed was the culprit. tow boot must have a functional OS on the emmc to work properly. I went back and ran manjaro phosh of the SD, downloaded it on the phone, expanded it, ran dd to write to emmc and now tow-boot works. At least it is not rebooting and I am able to connect it to the computer via usb and and currently flashing directly.
(02-16-2023, 02:50 PM)techariah Wrote: Well, after continued research I finally found a post that addressed the issue. Evidently that first move to flash the emmc that failed was the culprit. tow boot must have a functional OS on the emmc to work properly. I went back and ran manjaro phosh of the SD, downloaded it on the phone, expanded it, ran dd to write to emmc and now tow-boot works. At least it is not rebooting and I am able to connect it to the computer via usb and and currently flashing directly.
Thats interesting, also THANK YOU, also wtf tow-boot?? I've been trying to figure out whats going on for 3 days as my phone wont let me do anything but SD boot. ive been TRYING to use tow-boot to flash the emmc from clean but apparently thats not an option. But after booting postmarket and writing itself to itself, seems good. i feel like requiring a good emmc to flash emmc is a bit of an oversight..
in pinephone regular, tow-boot is installed on internal memory emmc.
in pp pro, tow-boot is installed on spi memory, which is separate from both emmc and sdcard.
hence, regular and pro have different installers. and my guess is that boot code is also sightly different.
do you have tow-boot in emmc mem in pp pro !?
  July 1 upgrade of Mobian Bookworm boot loops. mburns 9 9,707 02-25-2025, 08:27 AM
  Installing r2kaw and Tow-Boot to the SPI ethical_haquer 10 10,298 12-19-2024, 05:22 PM
Last Post: dukla2000
  How can boot from MicroSD after replacement of the main board u-kidjp 6 6,616 11-08-2024, 09:14 PM
  tow-boot, just bought pinephone pro stratofall 4 5,269 07-30-2024, 03:43 PM
Last Post: stratofall
  Tow-Boot, a new U-Boot option for Pinephone Pro and other devices Ulfnic 60 105,073 02-13-2024, 02:54 PM
Last Post: fxc
Brick Recovery without Tow Boot b34ux 10 11,587 02-02-2024, 07:07 PM
Last Post: reky
  What to do if your PinePhone Pro does not boot fxc 19 47,147 09-10-2023, 03:19 AM
Last Post: fxc
  Pine Phone won't boot into recovery mode ninjapig26@gmail.com 3 6,693 02-18-2023, 06:14 PM
Last Post: fxc
  create tow boot .img fox95 6 10,274 10-21-2022, 11:40 AM
Last Post: fox95
  No display on early boot after Manjaro update robocone 0 2,417 07-07-2022, 05:47 AM
Last Post: robocone
