Issue with booting Manjaro from encrypted NVMe drive on pbp
I am trying to operating a pbp with a system booted from an encrypted NVMe drive, but I stuck at the same step and would appreciate any help:
  •  I use an unencrypted partition on the eMMC acting as boot partition that holds the kernel and an initramfs. The latter was build taking among others the hooks `plymouth`, `plymouth-encrypt` and `lvm2` into account.
  • I am trying to boot a Manjaro (22.12) system which is located on a btrfs filesystem within the encrypted container on the NVMe.
  • As bootloader I use Two-Boot (on 1st partition of eMMC), which works and allows me to interrupt the foreseen boot process in order to boot from SD. If I do not interrupt it and try to boot via eMMC from the NVMe, the image file is provided (which is the only thing I get since a dialogue is shown just very shortly). Then it stucks with a black screen and a green power led.
I append the following options via the `extlinux.conf` file:
cryptdevice=UUID=<ID-OF-NVME-DEV>:<LABEL-AS-APPEARS-IN-MAPPER>:allow-discards root=/mnt/mapper/<LABEL-AS-APPEARS-IN-MAPPER>/ rootflags=subvol=@ rw rootwait audit=0 plymouth.ignore-serial-consoles
The ID, label and subvolume I use is the correct one, but I have to admit that I am unexperienced so far regarding btrfs.
The fact that I am not prompted for the passphrase indicates me that the hook is either not implemented correctly in the initramfs, or not called correctly.`mkinitcpio` did not show an irregular behaviour during the creation of the initramfs (build via chroot from within the system I try to boot). In another approach I tried the `enrcypt` hook instead of `plymouth-encrypt` which did also not succeed. Moreover, I read here that one should use`plymouth-encrypt` if plymouth is in use, which is the case for Manjaro.
Something that I recognised is that the initramfs is not build using the kernel sources of the system:
mkinitcpio -p linux ==> Building image from preset: /etc/mkinitcpio.d/linux.preset: 'default' -> -k 6.0.12-1-MANJARO-ARM -c /etc/mkinitcpio.conf -g /boot/initramfs-linux.img ...
cat proc/version Linux version 6.1.2-1-MANJARO-ARM ...
I would be happy for any hint that might be helpful to solve my issue.
I think you should check the initramfs hooks: Confirm that the necessary hooks
plymouth, plymouth-encrypt, and lvm2
pizza tower
are correctly included in the initramfs. You mentioned that you built the initramfs using mkinitcpio from within the system. Make sure that the hooks are specified in the /etc/mkinitcpio.conf file. You can check the contents of this file to ensure that the hooks are listed correctly.
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,590 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,237 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,358 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 4,104 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,649 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 4,001 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,249 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,486 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,469 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 5,327 11-14-2023, 10:57 AM
Last Post: trifleneurotic
