beware chatty 0.7.0~rc0-1
chatty 0.7.0~rc0-1 made its way into bookworm about Oct 26 but is not usable - the bottom of the window hides behind the keyboard so you can't see what you're typing, nor the message to which you are responding.  If that matters to you, hold-off on upgrades until that is resolved (or do an apt-mark hold chatty beforehand?)
I confirm this problem, it's very annoying. You can type your message in gedit or another editor, copy and paste it in Chatty but treebeard's suggestion is less cumbersome and preferable especially if the latest release candidate contains nothing really necessary for you.
Chatty 0.7.0~rc1-1 should resolve the issue, and is in unstable now and should roll to bookworm in a day or two.
(11-01-2022, 02:41 PM)treebeard Wrote: Chatty 0.7.0~rc1-1 should resolve the issue, and is in unstable now and should roll to bookworm in a day or two.
Yes it works, I've just updated Chatty. Don't forget to restart it obviously. I feel better now Big Grin
Working here too, though I'm seeing that it now takes a couple minutes to process a received MMS message so that needs some research.
Do you use a single APN for the Internet and MMS?
(11-06-2022, 01:32 PM)anonymous Wrote: Do you use a single APN for the Internet and MMS?
I have a T-Mobile SIM in the phone where that was occurring and it uses one APN for all.  The problem turned out to be due to a relatively recent change at T-Mobile and is resolved.
  Full disk encryption with calamares: beware of last testing upgrade! mdk 3 5,929 02-21-2025, 07:25 AM
Last Post: dragonhospital
  Chatty Matrix Decryption Key jojuma 2 3,742 02-26-2024, 12:48 PM
  Jabber with chatty user641 2 4,172 11-12-2023, 02:10 AM
Last Post: user641
  Chatty does not work after suspend mode user641 4 7,204 07-18-2023, 10:43 AM
Last Post: alaraajavamma
  Dist-upgrade and Chatty vs Gnome-Contacts biketool 9 12,031 09-30-2022, 08:53 PM
Last Post: treebeard
  Unable to send messages with chatty user641 0 2,388 09-07-2022, 04:35 AM
Last Post: user641
  Chatty - XMPP receiving photos - inline display doesn't work arkadione 2 5,114 07-10-2022, 03:16 AM
Last Post: arkadione
Sad Chatty can no longer start since the last update anonymous 10 13,863 06-08-2022, 01:03 PM
Last Post: Korac
  chatty v0.6 in Bookworm at last! treebeard 13 18,082 02-13-2022, 05:21 PM
  Chatty, SMS does not work - could hardware be at fault? AntonReiser 36 59,052 11-02-2021, 03:42 AM
Last Post: AntonReiser
