Jabber with chatty
Hello, I've been using jabber with chatty, I like it's simple interface. But I have the problem that omemo encryption works not with all contacts and when the phone goes into ibernation encrypted messages are not unencrypted after unlocking the phone. Is there a way around?
Hello, I think you should check OMEMO compatibility: Ensure that the contacts you're trying to communicate with also have OMEMO encryption enabled and compatible clients. OMEMO requires both parties to have OMEMO-capable clients and compatible configurations for encryption to work properly. geometry dash subzero
(11-10-2023, 01:23 AM)thomaschilton Wrote: Hello, I think you should check OMEMO compatibility: Ensure that the contacts you're trying to communicate with also have OMEMO encryption enabled and compatible clients. OMEMO requires both parties to have OMEMO-capable clients and compatible configurations for encryption to work properly.
Hey I checked that, that's not the problem, it works fine with dino for example, but chatty has this bug seems I will have to wait.
  Chatty Matrix Decryption Key jojuma 2 3,728 02-26-2024, 12:48 PM
  Chatty does not work after suspend mode user641 4 7,173 07-18-2023, 10:43 AM
Last Post: alaraajavamma
  beware chatty 0.7.0~rc0-1 treebeard 6 8,273 11-06-2022, 04:51 PM
Last Post: treebeard
  Dist-upgrade and Chatty vs Gnome-Contacts biketool 9 11,998 09-30-2022, 08:53 PM
  Unable to send messages with chatty user641 0 2,383 09-07-2022, 04:35 AM
Last Post: user641
  Chatty - XMPP receiving photos - inline display doesn't work arkadione 2 5,092 07-10-2022, 03:16 AM
Last Post: arkadione
Sad Chatty can no longer start since the last update anonymous 10 13,836 06-08-2022, 01:03 PM
Last Post: Korac
  chatty v0.6 in Bookworm at last! treebeard 13 18,040 02-13-2022, 05:21 PM
  Chatty, SMS does not work - could hardware be at fault? AntonReiser 36 58,928 11-02-2021, 03:42 AM
Last Post: AntonReiser
  How Do I Perform a Chatty Application Reinstall? rrholmes 2 4,946 07-13-2021, 01:11 AM
Last Post: rrholmes
