Chatty Matrix Decryption Key
I just connected Chatty to my Matrix account.
I verified this on another device I use Matrix on.
But I can't find an option to decrypt older messages.
What do I have to do to achieve this?
Do not answer this post thanks.
@jojuma looks like this is an ongoing issue with the purple-matrix plugin used by chatty to link to matrix. you can find and follow the open issue at the developer's github: https://github.com/matrix-org/purple-matrix/issues/18
alternatively, you can try enabling the experimental chatty/matrix integration: https://forum.manjaro.org/t/chatty-issue...forthefish
however, this forum is not the most appropriate place to troubleshoot generic apps. you will get better support if you seek it from the devs of the app you're having issues with. this forum is best used for discussing the "mobian ON the pinephone." Given this, I'm going to lock the thread, since this is not the appropriate place for this support issue.
  boot gets stuck shortly after disk decryption vortex 9 12,462 09-11-2024, 05:40 AM
Last Post: normangraves
  Jabber with chatty user641 2 4,147 11-12-2023, 02:10 AM
Last Post: user641
  Chatty does not work after suspend mode user641 4 7,144 07-18-2023, 10:43 AM
Last Post: alaraajavamma
  beware chatty 0.7.0~rc0-1 treebeard 6 8,254 11-06-2022, 04:51 PM
Last Post: treebeard
  Dist-upgrade and Chatty vs Gnome-Contacts biketool 9 11,964 09-30-2022, 08:53 PM
  Unable to send messages with chatty user641 0 2,370 09-07-2022, 04:35 AM
Last Post: user641
  Chatty - XMPP receiving photos - inline display doesn't work arkadione 2 5,082 07-10-2022, 03:16 AM
Last Post: arkadione
Sad Chatty can no longer start since the last update anonymous 10 13,724 06-08-2022, 01:03 PM
Last Post: Korac
  chatty v0.6 in Bookworm at last! treebeard 13 17,912 02-13-2022, 05:21 PM
  Help request: upgrade failed, locked out at decryption passphrase tiikeri 7 9,509 11-27-2021, 07:29 AM
Last Post: zetabeta
