Full disk encryption with calamares: beware of last testing upgrade!
I just upgraded my pinephone to the last testing via apt as always, and now the full disk encryption (calamares) passephrase prompt is looping with a "bad option" error. So I can no longer boot.
I have not investigated yet, just wanted to alert you.
I bet I can save myself by mounting the eMMC over USB, hopefully last time I had a similar issue I wrote about it: https://mdk.fr/blog/black-screen-at-boot...phone.html
Update:I tried another apt full-upgrade and a dpkg-reconfigure linux-image-6.6-sunxi64 over USB mass storage / chroot, no luck, but it seems a tad different, it now reads:
panel-sitronix-st7703 : ... midi_dsi_attach failed (-517) Is host ready?
pinephone-keyboard: Failed to read device ID: -6
Update: I noticed in my upgrade that phosh-osk-stub had an upgrade, so I downgraded it with `dpkg -i /var/cache/apt/archives/phosh-osk-stub_0.44.0-1_arm64.deb`, but no luck, still no keyboard at boot to decrypt my root fs Sad
Ask  devs in #mobian matrix room.  Share their fix.
Quote:Starting kernel ...
[  xx.xxxxxx] lima 1c40000.gpu: error -ENODEV: _opp_set_regulators: no regulator (mali) found
[  xx.xxxxxx] pinephone-keyboard 3-0015: Failed to read device ID: -6
MESA-LOADER: failed to open dri: /usr/lib/aarch64-linux-gnu/gbm/dri_gbm.so: cannot open shared object file: No such file or directory (search paths /usr/lib/aarch64-linux-gnu/gbm, suffix _gbm)
ERROR: Could not create window/display: EGL not initialized
BusyBox v1.37.0 (Debian 1:1.37.0-4) built-in shell (ash)
Enter 'help' for a list of built-in commands.
(initramfs)
(02-21-2025, 02:07 AM)dragonhospital Wrote: Ask  devs in #mobian matrix room.  Share their fix.
Hi, I have the same issue -- the core problem is in the absence of the library "dri_gbm.so", which is not copied during initramfs generation, I see the error below:
ln: failed to create symbolic link '/var/tmp/mkinitramfs_87Ugk3//usr/lib/aarch64-linux-gnu/dri/libdril_dri.so': File exists
I did a check of the initramfs contents, by copying it to the host and added `/usr/lib/aarch64-linux-gnu/gbm/dri_gbm.so` manually -- that requires unpack and pack of existing initramfs. After that, Pinephone booted well.
Looks like the issue is in initramfs generation scripts, so with `osk-sdl` the initramfs would be regenerated in wrong way.
In Matrix channel, there were a suggestion to switch to more recent OSK `unl0kr` and that helped in my case.
Safe steps:
  • change `/etc/crypttab` file, to point to proper keyscript `keyscript=/usr/share/initramfs-tools/scripts/unl0kr-keyscript`
  • install `unl0kr`, automatically regenerated initramfs will contain both OSKs
  • remove `osk-sdl` and initramfs will be regenerated again, but will contain only `unl0kr`
Good thing what initramfs is 3 times (!!!) less than with osk-sdl with all deps:
$ ls -lh /boot/initrd.img-6.12-sunxi64* -rw-r--r-- 1 root root 29M Feb 14 18:53 /boot/initrd.img-6.12-sunxi64 -rw-r--r-- 1 root root 99M Feb 14 16:45 /boot/initrd.img-6.12-sunxi64.bak
Bad news -- the `unl0kr` doesn't support the Pinephone keyboard.
d4s  how is initramfs  unpacked&packed?
Your instructions is for everyone that has not booted. Trixie users do not  reboot!
First back up /etc/crypttab
Second change osk-sdl-keyscript in  /etc/crypttab to unl0kr-keyscript
Third sudo apt install --reinstall unl0kr
chroot steps if already rebooted and broke.
First  download 2023  mobian img from mobian.org
Second  write mobian img to  spare SD card
Third  put SD card in pinephone and boot while holding down volume button
Fourth when fresh mobian loaded use  password 1234  and connect to internet
Fifth  open terminal console  and sudo su
Sixth apt install cryptsetup-bin
Seventh lsblk to find  boot and  encrypted  fs of onboard mmc
Eight cryptsetup luksOpen /dev/mmblkXpY  root    X and Y are numbers from lsblk
Ninth mount /dev/mapper/root /mnt
Tenth mount /dev/dev/mmblkApB /mnt/boot A and B are numbers from lsblk
Eleventh for i in /dev /dev/pts /proc /sys /run; do sudo mount -B $i /mnt$i; done
Twelfth sudo chroot /mnt
Thirteenth  back up /etc/crypttab and change osk-sdl-keyscript in  /etc/crypttab to unl0kr-keyscript
Fourteenth  sudo apt install --reinstall unl0kr
exit and reboot
unl0kr crashes w/USB keyboard. Bug. Use onscreen keyboard to unlock and boot.
Camera now broken too, can't load firmware. Bug.
  mobian calamares fail merom 2 5,096 04-29-2025, 02:10 PM
Last Post: mdk
  Calamares initialization failure GOOOFBALLL 6 9,424 03-26-2025, 02:45 PM
Last Post: jlaba
  Upgrade to Mobian (Trixie) Staging biketool 13 12,179 12-29-2024, 10:35 AM
  How to use an NVMe disk as rootfs Smaking 3 3,625 11-29-2024, 06:51 AM
Last Post: walter1950
  boot gets stuck shortly after disk decryption vortex 9 12,791 09-11-2024, 05:40 AM
Last Post: normangraves
  What actions needed to keep on mobian testing user641 3 6,367 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 2,558 09-01-2023, 11:29 AM
Last Post: Mahgue
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 7,180 03-01-2023, 04:45 PM
Last Post: anonymous
  No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED 3x5co 1 3,679 01-04-2023, 06:46 PM
Last Post: 3x5co
  Receive MMS fails after Nov 27 upgrade treebeard 17 20,525 12-12-2022, 05:09 AM
