Manjaro update: wxgtk dependency issue
Hi there,
my PineBook Pro from spring 2020 runs Manjaro linux. Not sure which version, the command "ver" in a terminal doesn't tell me anything. Either way, I'm being prompted up update but when I do, I get this popup which tells me
could not satisfy dependencies:
- removing wxgtk-common breaks dependency 'wxgtk-common' required by wxgtk2
Everything else seems to work fine so far, but obviously I should run the update at some point. Any advice?
Thanks!
Vinay
(09-06-2022, 11:49 AM)Vinay Wrote: Hi there,
Thanks!
Vinay
maybe good idea join Manjaro forum , that best place ask for help ..   also archlinux news +wiki   maybe bookmark .
i no run manjaro   but  have read here   "  https://archlinux.org/news/wxwidgets-32-...ervention/ "
Thank you for your response. Removing wxgtk2 as suggested in your link worked for me. And indeed I considered joining the Manjaro forum too for this if no one could help. Then again as these PineBooks were shipped with Manjaro anyway, it is good to have this advice on here too. Cheers!
(09-08-2022, 04:46 AM)Vinay Wrote: Thank you for your response. Removing wxgtk2 as suggested in your link worked for me. And indeed I considered joining the Manjaro forum too for this if no one could help. Then again as these PineBooks were shipped with Manjaro anyway, it is good to have this advice on here too. Cheers!
Happy it work for you ..  Hope you enjoy rest of your PBP linux journey.
I don't know about "ver" but I expect "uname -a" should tell you about your operating system. (Though I can't be certain that this actually works in Manjaru.
:wq
(09-08-2022, 10:08 AM)KC9UDX Wrote: I don't know about "ver" but I expect "uname -a" should tell you about your operating system. (Though I can't be certain that this actually works in Manjaru.
Yeah, uname -a indeed responds with "5.7.19-1-MANJARO-ARM #1 SMP Wed Sep 2 20:43:09 +03 2020 aarch64 GNU/Linux
". I think I learned about the ver command back in the days and it has worked for me since, running SuSE linux and OpenSuSE. Things differ between distributions apparently. I also learned "acpi -V" doesn't quite work as expected. It tells me my battery has 0% remaining even though the icon in the plasma bar (whatever it is called) tells me it is at 38% currently. I'll try to update my command line skills, but I won't pollute this thread any further. As it is now, I hope it can be a useful resource for those running into this same upgrade issue. Either way, thanks all for your help![/color]
[/font]
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,590 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,240 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,358 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 4,105 03-08-2024, 08:41 AM
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 4,133 03-01-2024, 06:46 PM
Last Post: Puckla
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,651 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 4,002 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,249 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,488 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,469 12-07-2023, 03:11 PM
