Error trying to update Manjaro software
Hello. I receive the following error while trying to update software in Manjaro using Add/Remove Software:
Invalid or corrupted database (PGP signature)
Failed to synchronize databases
If anyone is able to advise I’d be grateful. I’m pretty inexperienced when it comes to Linux.
Hi there,
did u try updating outdated sig keys yet ... in terminal?
$sudo pacman-key --refresh-keys
$sudo pacman-key --populate archlinux manjaro
$sudo pacman -Syy
(08-18-2022, 08:09 AM)josmo Wrote: Hi there,
$sudo pacman -Syy
Thanks for responding! Refresh keys made no changes. Populate gave:
gpg: error reading key: No public key
-Syy output was:
error: GPGME error: No data
error: failed to synchronize all databases (invalid or corrupted database (PGP signature))
what about
sudo pacman -S manjaro-keyring manjaro-arm-keyring
 ezik
(08-31-2022, 12:58 PM)shulamy Wrote: what about
 ezik
Output:
error: GPGME error: no data
error: database ‘core’ is not valid (invalid or corrupted database (PGP signature))
error: database ‘extra’ is not valid (invalid or corrupted database (PGP signature))
error: database ‘community’ is not valid (invalid or corrupted database (PGP signature))
maybe bad mirror
ezik
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,638 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,328 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,434 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 4,155 03-08-2024, 08:41 AM
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 4,151 03-01-2024, 06:46 PM
Last Post: Puckla
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,687 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 4,040 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,319 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,547 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,504 12-07-2023, 03:11 PM
