Manjaro Gnome 22.06 pamac update fail/soft-bricked-OS
Is anyone else having issues updating the Pinebook Pro Manjaro ARM GNOME 22.06 image?
I attempted to update the system on SD card (and internal eMMC) via "Add/Remove Software" (pmac?).  It locks up at "Checking Integrity...".  Then after shutting down, the OS won't boot.
I have also been having that issue, but I haven't been able to find out what is causing it. It appears it's an issue with the Gnome version, as I flashed the Plasma version to the same card and it works just fine.
I believe the reason it won't boot is because it moves quite a few of the essential files before beginning the upgrade. If I try to open any application before powering it off, such as settings or the terminal, it gives me a message saying the application isn't found.
(08-18-2022, 01:32 PM)creeker99 Wrote: I have also been having that issue, but I haven't been able to find out what is causing it. It appears it's an issue with the Gnome version, as I flashed the Plasma version to the same card and it works just fine.
I had the same issue.  It is as if the OS only exits in memory...  I thought it was because I killed the /usr/bin/pamac-manager --gapplication-serivice after the lock on "Checking Integrity..."
What I can gather it pamac takes a VERY LONG time when checking package integrity...
"sudo pacman -Scc"
"sudo pacman -Syyuu"
might work...I broke the OS image again...will test later
I may have to just let it sit as well, although I left it for a half hour at one point. I've got Armbian Gnome working well at the moment, so I may just use that for a while. I'm more familiar with Debian based distros anyway, but I was hoping to try something new as usual!
Probably the best idea. I assume the Manjaro-ARM-GNOME Pinebook Pro community is very small.
It might be the case that the image is so unstable that one shouldn't update between releases.
I tried the pacman -Syyuu update command and the Pinebook Pro randomly froze in the downloading of packages, so I am going to forget about this.
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,176 08-09-2025, 06:53 AM
Last Post: Sb2024
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,614 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,299 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,402 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 4,142 03-08-2024, 08:41 AM
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 4,147 03-01-2024, 06:46 PM
Last Post: Puckla
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,673 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 4,029 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,299 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,534 12-11-2023, 03:47 AM
Last Post: calinb
