Any word on Pinephone Pro performance
Just got word my pinephone pro has shipped.  Takes a week or so to get to me.
Anyone with any experiences on pinephone pro that may have already been received:  stability, consistency, sms, mms, gps, etc.
thanks,     tom kosvic
(01-24-2022, 09:00 AM)tckosvic Wrote: Just got word my pinephone pro has shipped.  Takes a week or so to get to me.
thanks,     tom kosvic
I've been using the phone for a few days using KDE Plasma manjaro. Today there is a problem of freezing the lock screen, it is solved by disabling automatic suspend. The autonomy of battery is still at a low level. The speed of work is higher compared to the original pinephone, and today it is comfortable to use the phone (the speed of GUI is at the level of android smartphones for $ 100-150). Calls and sms work, mms did not check. GPS works fine, accuracy is average, cold start is long in time 3-5 minutes. Compared to the original pinephone, this is a Sonic Hedgehog. Ready to answer questions.
  New PinePhone user issues greenpineuser 8 8,328 12-19-2024, 09:47 PM
Last Post: emilianojay
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 10 19,588 10-04-2024, 12:01 AM
Last Post: spazz
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 3,979 07-03-2024, 08:38 PM
  link for supported pinephone os manjharo et all penguins_rule 3 4,757 05-09-2024, 03:02 AM
Last Post: Eugo
  systemic issue pinephone penguins_rule 3 5,031 04-02-2024, 11:52 AM
  new PinePhone upgrade issue WhiteHexagon 5 7,865 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Can't add micro SD card to Pinephone thorensjubilee 7 8,962 02-27-2023, 10:21 AM
Last Post: mikehenson
  Pinephone Freeze kmsgli 14 19,513 02-04-2023, 08:35 PM
Last Post: Westslope
  Pinephone craches after each call neithan76 2 4,366 07-29-2022, 11:47 AM
Last Post: Chief
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 54,293 07-28-2022, 12:40 PM
Last Post: johaennessen
