Manjaro - Internet connection sharing requires dnsmasq (but the dep isn't declared)
Attaching a Rockpro64 via its ethernet port to my PBP, it's supposed to be possible to "share" the PBP's wifi connection with it, which actually involves setting up NAT & DHCP automatically under the hood.
Network Manager > Edit Connections > Wired connection 1 > IPv4 Settings > Method: Shared to other computers
But it didn't work.
After banging on it all morning, I found this article,
https://fedoramagazine.org/internet-conn...rkmanager/
which mentions that it uses dnsmasq. Check; dnsmasq is not running. Check; package dnsmasq is not installed. Install dnsmasq; now it works.
That ought to be declared as a dependency.
Edit: When installing NetworkManager, it does list dnsmasq as an optional dependency for connection sharing. But the user doesn't necessarily ever see this message. It should either be a hard dep, or Network Manager should detect the absence of dnsmasq & give an informative error message, rather than just mysteriously not working.
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,708 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,424 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,523 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 4,214 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,748 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 4,089 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,424 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,664 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,559 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 5,454 11-14-2023, 10:57 AM
Last Post: trifleneurotic
