Boot from USB - What's about resizing the partitions?
Hello together
Yesterday my new Rock64 2GB arrived. Very nice piece!
I want to use this for IOT "iobroker"
There are for Rock64 ready made Armbian images.
I configured the Rock64 to boot from USB and create an USB3.0-Memorystick with this bootable iobroker Image.
It boots up, but then it stops. Could it be, that the memory or partitions of the 64GB Stick has to be resized?
When I use an SSD by an SATA to USB3.0 Adapter, I will not boot up at all.
I know this partition resizing of bootable USB-devices from the Raspberry Pi.
How is it at the Rock64?
Does anybody has a manual for this?
Thank you!
(02-28-2019, 01:38 AM)hg6806 Wrote: Hello together
Thank you!
I haven't played with a new armbian install in a while but shouldn't it resize on first boot?
Failing that install/use gparted to resize.
I mean, after booting the first time from SD card, you have to resize/expand the filesystem.
How do you do that on a USB-ästick or SSD drive?
Is there a How-to?
(02-28-2019, 05:46 AM)hg6806 Wrote: I mean, after booting the first time from SD card, you have to resize/expand the filesystem.
Is there a How-to?
Use gparted
What kind of partition I have to expand?
(02-28-2019, 06:00 AM)hg6806 Wrote: What kind of partition I have to expand?
It should be the largest one, just expand it by dragging the end of the partition to the end of the drive. Then click on apply.
  Rock64 won't boot dstallmo 0 338 12-27-2023, 10:34 AM
Last Post: dstallmo
  arch rock64 does not boot nemnob 0 595 07-09-2023, 03:28 AM
Last Post: nemnob
  Disabling last mount time check on boot acwest 0 629 03-03-2023, 09:24 PM
Last Post: acwest
  Rock64 Rev3 doesn't boot and leds blinking fast dishins 6 7,813 06-30-2022, 06:28 PM
Last Post: rookie_267
  my rock64 can't boot rookie_267 0 1,055 06-27-2022, 06:52 PM
  Setting a MAC on Rock64 U-Boot kiriakos 2 3,587 03-23-2021, 04:51 AM
Last Post: kiriakos
  Boot from USB 3.0 with hub Turbo 0 2,112 12-20-2020, 02:24 PM
Last Post: Turbo
  Unable to boot armbian fchazal 2 3,873 05-19-2020, 06:43 PM
Last Post: Rocklobster
  Rock64s will not boot any OS camosoul 2 3,439 05-19-2020, 06:38 PM
  Help me understand the boot up process olivercfc 0 1,936 11-10-2019, 08:30 AM
Last Post: olivercfc
