arch rock64 does not boot
I followed this guide: https://archlinuxarm.org/platforms/armv8...ner/pine64  to install arch on an sd card and then successfully booted to rock64, but I did the mistake and run "rm /boot/boot.scr" and now I'm unable to boot again.
After than I tried following again the same steps (from step 5-10) a couple of times but I always get the same result (when I boot all the leds are working and the the monitor does not display anything)
Any ideas on what is going on and how I can debug this?
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 158 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,376 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 342 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 627 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 621 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,477 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,915 10-09-2023, 03:31 AM
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 655 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  Disabling last mount time check on boot acwest 0 632 03-03-2023, 09:24 PM
Last Post: acwest
  DietPi OS for ROCK64 MichaIng 41 33,497 12-07-2022, 08:22 PM
Last Post: luminosity7
