Disabling last mount time check on boot
Every time my Rock64 boots, I get an error about the Superblock last mount time is in the future. As I don't have a working hardware clock, this happens on every boot, force an fsck and adding to the boot time. When searching for this error, most of the recommendations are to fix the clock, but that isn't really feasible on a device that doesn't have one. Seeing as this check happens before mounting the filesystem, a solution like fake-hwclock isn't likely to be useful either. I can't be the only one with this problem...
  Rock64 won't boot dstallmo 0 341 12-27-2023, 10:34 AM
Last Post: dstallmo
  arch rock64 does not boot nemnob 0 599 07-09-2023, 03:28 AM
Last Post: nemnob
  Rock64 Rev3 doesn't boot and leds blinking fast dishins 6 7,816 06-30-2022, 06:28 PM
Last Post: rookie_267
  my rock64 can't boot rookie_267 0 1,055 06-27-2022, 06:52 PM
  Setting a MAC on Rock64 U-Boot kiriakos 2 3,588 03-23-2021, 04:51 AM
Last Post: kiriakos
  Boot from USB 3.0 with hub Turbo 0 2,112 12-20-2020, 02:24 PM
Last Post: Turbo
  Unable to boot armbian fchazal 2 3,874 05-19-2020, 06:43 PM
Last Post: Rocklobster
  Rock64s will not boot any OS camosoul 2 3,439 05-19-2020, 06:38 PM
  Partitioning encrypted CCC Carbon Copy Cloner AND setting up Time Machine on HDD vidin 0 1,793 05-10-2020, 01:08 PM
Last Post: vidin
  opemmediavault plugin error on "Check" clach04 0 4,617 04-21-2020, 10:13 PM
Last Post: clach04
