opemmediavault plugin error on "Check"
I've been experimenting with pre-release and stable builds of Open Media Vault for rock64 (see https://github.com/ayufan-rock64/linux-build/issues/426 but right now I can only get stable to boot).
Occasionally when hitting "Check" for plugins I get and error popup with:
Failed to execute command 'export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; apt-get update 2>&1' with exit code '100': Reading package lists... E: Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarily unavailable) E: Unable to lock directory /var/lib/apt/lists/
Error #0:
OMV\ExecException: Failed to execute command 'export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; apt-get update 2>&1' with exit code '100': Reading package lists...
E: Unable to lock directory /var/lib/apt/lists/ in /usr/share/openmediavault/engined/rpc/apt.inc:220
Stack trace:
#0 /usr/share/php/openmediavault/rpc/serviceabstract.inc(565): OMVRpcServiceApt->{closure}('/tmp/bgstatus7L...', '/tmp/bgoutputDu...')
#1 /usr/share/openmediavault/engined/rpc/apt.inc(224): OMV\Rpc\ServiceAbstract->execBgProc(Object(Closure))
#2 [internal function]: OMVRpcServiceApt->update(NULL, Array)
#3 /usr/share/php/openmediavault/rpc/serviceabstract.inc(123): call_user_func_array(Array, Array)
#4 /usr/share/php/openmediavault/rpc/rpc.inc(86): OMV\Rpc\ServiceAbstract->callMethod('update', NULL, Array)
#5 /usr/sbin/omv-engined(537): OMV\Rpc\Rpc::call('Apt', 'update', NULL, Array, 1)
#6 {main}
I think it is failing due to missing sudo, running in ssh session as root works:
root@rock64:~# export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; apt-get update 2>&1
  Disabling last mount time check on boot acwest 0 607 03-03-2023, 09:24 PM
Last Post: acwest
  Gpio error wile using GPIOtest.py Aditya Rastogi 0 1,898 01-31-2019, 02:41 AM
Last Post: Aditya Rastogi
  gstreamer error sdarktemplar 1 2,756 08-02-2018, 11:08 PM
  docker contaainer error on "docker login" edwinbmiller 0 1,576 06-18-2018, 10:08 AM
Last Post: edwinbmiller
  Apt-get update duplicate entry error Jxck 1 3,004 06-02-2018, 02:26 PM
Last Post: evilbunny
  mmc0: error -110 edwinbmiller 6 7,034 03-29-2018, 12:44 PM
  Error building Rock 64 kernel Bapple 3 4,616 02-13-2018, 08:23 AM
Last Post: xalius
Question LoadTrustBL error when booting pedroz 0 1,622 02-09-2018, 08:35 AM
Last Post: pedroz
  Error when installing some packages - Installing new rk3328-rock64.dtb. msg thewonderer 0 1,810 02-07-2018, 05:22 AM
Last Post: thewonderer
  need some help with a dpkg error dkryder 0 1,466 12-25-2017, 03:09 PM
Last Post: dkryder
