Unable to boot armbian
I can't make any armbian image boot from sdcard on my ROCK64 rev2.
The sdcard is fine and well written with a single ext4 partition on it but the board just doesn't boot and leaves me a blank screen.
I have no problem running ayufan debian images but they have a vfat boot partition instead of armbian images.
Is there anything I'm missing ? Could anybody please help me ?
(04-20-2020, 06:01 AM)fchazal Wrote: I can't make any armbian image boot from sdcard on my ROCK64 rev2.
I can't get anything to boot.
My thread was also ignored.
I have a custom ArchLinux Arm script that I used to install back in February, and that one works. I bought 3 more Rock64 boards and they don't boot. No errors, nothing. They just light up all their lights and do nothing.
Away
On what platform are you formatting and burning the image onto the SD card. Try using SD Formatter and Win32 Disk Imager. I've heard a number of people have experienced problems with Balena. Try my suggestion. You've nothing to loose.
  Rock64 - not booting after Armbian update helpmerock 6 1,159 03-27-2025, 08:26 AM
  How to boot an older, working kernel bits 0 695 11-01-2024, 04:43 PM
Last Post: bits
  problem with debian emmc boot G4zCDzWb 10 4,881 11-01-2024, 04:32 PM
Last Post: bits
  arch rock64 does not boot nemnob 1 1,624 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  Rock64 won't boot dstallmo 0 1,092 12-27-2023, 10:34 AM
Last Post: dstallmo
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 1,511 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  Disabling last mount time check on boot acwest 0 1,300 03-03-2023, 09:24 PM
Last Post: acwest
  USB3.0 Issues at DietPi(Armbian) #22.02.1 t4_4t 3 3,724 08-15-2022, 06:58 PM
Last Post: TRS-80
  Rock64 Rev3 doesn't boot and leds blinking fast dishins 6 10,202 06-30-2022, 06:28 PM
Last Post: rookie_267
  my rock64 can't boot rookie_267 0 1,860 06-27-2022, 06:52 PM
